widest tire for 17x9 WS6 wheels?
Old Jan 26, 2003 | 10:44 PM
LethalTA's Avatar
I want to know what the widest tire is that i can get for my 17x9 stock WS6 wheels? i was wanting to get 315/35/17 if possible....i have 275/40/17 currently. If i have to have 17x11 inch wheels where can i get 17x11 inch WS6 wheels?
Old Jan 26, 2003 | 10:47 PM
96z's Avatar
96z
315's are really pushing it on a 9" rim 9.5" would be the absolute lowest I would go. 315's would only be heavier and buldge like crazy. Check out www.ws6.com he widend his WS6 rims to 11"
Old Jan 26, 2003 | 11:43 PM
Dave 96TA's Avatar
you can max them out with 285/35 or 285/40 but its a tough combo to find. if you want 11" wide WS6 wheels, goto a wheel repair center and ask them to widen it 2", they can cut it and weld in a 2" spacer around the interior wall.
Old Jan 27, 2003 | 07:21 PM
LethalTA's Avatar
thanks guys!....will welding a spacer in th wheel effect the strength of the wheel? or the balance?
Old Jan 28, 2003 | 07:56 PM
Josh-'04 GTO's Avatar
TTT for ya. I have the 17x9 ROH Snypers and am dying to get some 315s on this pig. 275s are getting absolutely pounded out back. Definately would like to hear more about this.
Old Jan 28, 2003 | 08:39 PM
rskrause's Avatar
Moderator
It makes more sense to buy new wheels compared to having them widened. I am using 285/40/17 BFG G-Force KDW out back. A 315 is just too wide for a 9" rim, IMHO.
Rich Krause
Old Jan 28, 2003 | 09:07 PM
fozziez28's Avatar
275/40zr17 is about as big as you can go on 17x9. You will have to get 11's to put on 315s. Check out how much those are a tire before you get your rims widened. They will break the bank! Thats why when i got my chrome zr-1's i got 9.5 all around. Plus they will stick out horribly on a trans am. Getting the piece welded in will reduce the strength of the wheel. Good luck in your decision. Thanks, Michael
Old Jan 28, 2003 | 10:12 PM
LethalTA's Avatar
Hey Rich, how much wider is a 285/40/17 than a 275?.....any pics of what they look like on T/A?
Old Jan 28, 2003 | 10:18 PM
LethalTA's Avatar
Also if i do get the 17x11's and the 315's, will they fit inside my stock wheelwell without modification? people are telling me i might need minor massage work inside my rear fenderwells.
Old Jan 28, 2003 | 10:47 PM
JTS95TA's Avatar
Yes you can mount a 315 35 17 on a 9" wide wheel. As others said it will not be as effective as it would be if mounted on a 11" wide wheel. I have seen 2 cars with stock 10 spoke SS wheels and another on 95 Z28 with SS wheels. To my surprise the tires looked really good on those wheels and did not bulge as much as some of these guys think. Now, as I said before the tire will probably not be as effective, but yes you can mount them on and they actually look pretty good.
Hope this helps.
Old Jan 28, 2003 | 10:48 PM
96z's Avatar
96z
They are a cm wider than the 275's, probably not even a noticable difference when on the car.
Old Jan 29, 2003 | 12:10 AM
Caged Monkey's Avatar
I heard that with the f-bodies, the old Corvette Grand Sport wheels are 17x11's for the rear and I think they were 17x9.5 in the front. The backspacing is supposed to be just right to fit it inside the fender and all you have to do is roll the lip and do a little massaging of the inner fender (with the rear seat up and locked when you do it or you will never be able to get it to lock back into place again) to eliminate any small rub spots. You may also have to grind down the bump stop down there in the wheel well too. The wheels were the black painted ZR-1 style if you dont know what I am talking about but they will fit inside the fenders with 315's. Just a little bit of info for you.
Old Jan 29, 2003 | 10:48 AM
Acct 23749's Avatar
do not go over 285 on a 9.5 inch rim
any thing wider will not give you more traction, it may actully help you lose traction. beside it looks horrible
LD Kirk
Apr 30, 2015 08:54 AM
cristian1311
Mar 4, 2015 04:45 PM
sloppytot
Feb 25, 2015 08:30 PM
dpw21562
Jan 23, 2015 04:58 PM
Jason Short
Jan 19, 2015 06:33 PM
