2 CATS on a CAMARO?
Old Jan 26, 2003 | 09:16 PM
Chrisz24's Avatar
2 CATS on a CAMARO?
I was looking at a previous post and somewhere it had something about duel cats on Camaro's.
it also made me think about when I bought my Borla how there was a model for V8 camaro's with 2 cats and Camaro's with 1 cat.
I know the V6 has one, but where do they put 2 on the V8 and which ones have them?
Why would they do that with a car with single exhaust I pipe?
Old Jan 26, 2003 | 09:32 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
2 cats will make the NOx and other polutants go down as compared to having jsut one cat. the more the cats the cleaner the exhaust. im not sure on which years had 2 , but i know at least some of the LS1's had 2
Old Jan 27, 2003 | 02:09 AM
morb|d's Avatar
the 98+ SS cars have 2 cats in parallel (one for each side). they're farther upstream so they warm up quicker. this is good for lowering cold start emissions. its also good for exhaust flow, which means slightly less back pressure.
Old Jan 27, 2003 | 12:06 PM
TheV6Bird's Avatar
I was reading a past issue of Car Craft, where a reader wrote in and asked about cats on his older car, and flow from them. Car Craft said the rule of thumb was the farther back a cat is, the better it flows, and the closer a cat is to the engine, the better it is for emissions.
Old Jan 27, 2003 | 03:59 PM
MustangEater82's Avatar
I have a stock setup form a 96 z28, it had a dual cat setup.
I-pipe started right about wear the torque arm ends. I had a 2.5 in. pipe made to connect it to my y-pipe.
the cAts were side by side under passneger seat, one form each y-pipe.
Old Jan 27, 2003 | 05:16 PM
99blackSS's Avatar
The cats on my car are connected directly to the manifold. My car would be fine without that bump on the passenger side but GM was to lazy to take it out.
alphaauto
Jan 23, 2015 07:42 AM
spearous
Jan 12, 2015 11:03 AM
Jan 5, 2015 07:14 PM
Dec 1, 2014 08:08 AM
turbo_Z
Aug 19, 2002 10:50 PM
