Idle problem
Old Jan 26, 2003 | 09:59 AM
max929's Avatar
Idle problem
Here is the problem.
Car idles at 750rpm and drops down to 400rpm then back up to 750rpm approx every 4 to 6 seconds.
I unplugged the Idle Control Motor and idle goes up to 1000rpm and barely drops to 900rpm. What do you think my problem is?
Old Jan 26, 2003 | 09:34 PM
Rodrigues's Avatar
I would go and have it scanned to see what your IAC is reading. It could be a bad IAC module
Old Jan 27, 2003 | 02:35 AM
SStupid's Avatar
ICM
Remove your throttle body and clean both it and the ICM.
Old Jan 27, 2003 | 07:38 AM
Re: ICM
I think you mean IAC, right? The Ignition Coil Module would not have much to do with the throttle body.
Old Jan 27, 2003 | 08:24 AM
SStupid's Avatar
Oh yeah
Dude! My bad. Yeah, I mean the IAC. All these damn acronyms! Thanks, Shoe.
Old Jan 27, 2003 | 09:23 AM
max929's Avatar
Thanks guys.
Pulled the IAC off yesterday and it was pretty dirty and the gasket appeared to be cracked (not sure if that happened when IO took it apart). Should have it back together today.
lt1matt
Mar 21, 2015 07:35 PM
edman
Mar 13, 2015 09:39 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
edman
Jan 25, 2015 02:41 PM
slothgrant
Aug 22, 2002 03:01 PM
