Front door speaker trim
Old Jan 22, 2003 | 01:16 PM
z28sinx's Avatar
Stupid question, but how do I remove the front door speaker trim to change out the speakers, does it just pull out?
Old Jan 23, 2003 | 12:07 AM
PaulN64's Avatar
you actually have to remove the door panel to get to them. I've heard people who have removed the speaker girlls to take the speakers out, but I can't see how it can be done
Old Jan 23, 2003 | 01:47 PM
CalPoly96Z's Avatar
The door is usually attached by a series of pop-screws and also some screws located in places around the door handle... I haven't taken apart my door panel to replace the speakers yet but I'm planning on doing it soon. I have done it in other cars and they were all the same. When you locate all the screws and pop off all of the pop-screws then typically you have to lift up on the door panel before you can remove it. I will let you know more information as I get it.
Old Jan 23, 2003 | 01:57 PM
firebirdude's Avatar
This is correct. There are no pop-screws. Pull out the switch panel that has the window switches and auto-doorlock switch. Disconnent everything. Then the plastic behind the actual door lever has 1 screw remove it and work it off. Then there is a larger screw behind that. Remove it. Directly behind the side mirror is a small triangle shaped piece with 1 screw. Remove it. There are 2 I believe in that little map holder or pocket on the door. There is another on the underside of the armrest. I think that's it....... I think. Then grab hold of the armrest and pull directly up. You will feel it come out of place, then you can pull out and off.
Old Jan 23, 2003 | 02:58 PM
rockcamaro97's Avatar
u can take the cover off but it has to be cut off. Just use an exacto knife if u wanna remove it. U still cant get to the speakers though. I did this to paint them.
Matt
Old Jan 23, 2003 | 05:01 PM
z28sinx's Avatar
Thanks for the replies everyone. I didn't realize all the work involved.
Matt
So how did you get the covers back on?
Old Jan 23, 2003 | 05:53 PM
they haev 2 or 3 clips and the 2 peices u gotta cut. the peices u gotta cut are on the top and bottom but the clips are on the sides. u can pop them out and use them to hold them back in
Matt
Old Jan 23, 2003 | 09:50 PM
Distephano's Avatar
I managed to remove my stock door speakers and put new ones in though the grill hole. Though, my stock speakers were only mounted with 2 screws The car had some badly done system in it when I bought it. Go figure. So, I just mounted the speakers with the screws that were there. When they get louder, the vibrated some though. So, when I get my car back from the shop (I hope this weekend! Its been almost 3 months! I miss my car!) I'm gona pull the door panels off and mount them better. Doing this along with a full tune up (Minus plugs, cuz my wires aren't here yet)
Rod Bender
Jan 1, 2015 03:18 PM
regular Joe
Aug 8, 2002 03:47 PM
MilkyClr69
Jul 29, 2002 10:01 AM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
