Best clutch/flywheel set up
Old Sep 29, 2009 | 04:51 PM
kamon8404's Avatar
Well, after doing extensive reading on the different clutch options I still haven't found information i'm looking for.
Well the I have a 96 LT1 powered car. M6.
Right now it has a autozone lifetime warranty duralast clutch in it. Its definitely going to need to be replaced.
So my plan was to take the clutch and pressure plate out and take it back to autozone for a brand new pressure plate and disc.
Then I was going to just buy a different disc to meet my needs better.
I plan to keep the stock flywheel.
Mods:
CAI, Bored TB, Ported Intake, Long tubes, Flashed ECU, 1.6 Roller rockers, 160 thermostat, hurst short shifter.
So which disc would be best? (keeping in mind its a stock rear end), its a daily driver, and I barely beat on my cars.
I hear the spec 2+ might be the best option. Any input on this?
Old Sep 30, 2009 | 08:20 PM
kamon8404's Avatar
Any input at all?
Old Sep 30, 2009 | 08:25 PM
rclearyiii's Avatar
I have a 96 m6 as well and use a stock clutch disc with zero issues at all. If you don't rag it out on a regular basis, I see nothing wrong with staying stock.
Bob
Old Sep 30, 2009 | 11:55 PM
97SS0594's Avatar
your current clutch setup is perfectly fine. your probably making very little over stock HP numbers so id just rock out the stocker
Old Oct 6, 2009 | 07:24 AM
kamon8404's Avatar
Yeah I'm probably just gonna go with a stock setup since I wont beat on the car like the prevous owner did.
Old Oct 7, 2009 | 06:58 PM
87Aerocoupe's Avatar
I'm kinda in the same boat except I'm getting ready to put in my 383 and I went to Valeo's website and brought an LT4 clutch for $288 and I'm going to buy a SPEC 3+ disc, I'm also going to get the McLeod blowshield for the LT1 T56.
HectorM52
Jul 30, 2017 11:46 AM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
z28leno
Mar 12, 2015 07:42 AM
FredM
Mar 6, 2015 03:04 PM
Jan 23, 2015 01:13 PM
