RPM drops and then stall at stop lights
Old Sep 15, 2009 | 01:01 PM
Gripenfelter's Avatar
This is for a friend's 2002 Escalade.
Whenever he slows down or stops the truck's idle drops very low or it stalls.
Suggestions?
Old Sep 15, 2009 | 08:26 PM
johnny6's Avatar
Scan it for codes first then move on to the basics, fuel filter, fuel injector cleaner etc. etc. Sound like my car after it's trying to re-learn the pcm.
Old Sep 16, 2009 | 07:01 AM
AL SS590 M6's Avatar
Moderator
Yeah check for codes and proper preventative maintainence items then I'd look at/clean the IAC and it's passages.
Old Sep 16, 2009 | 12:33 PM
IRONFIST's Avatar
My TA is doing the exact same thing...
I changed the TPS, it did nothing. Check engine light comes on.. then turns off, does your friends truck do the same thing?
Old Sep 16, 2009 | 01:04 PM
Sparkz28ss's Avatar
you could try cleaning the MAF ...that may help
Old Sep 17, 2009 | 02:30 PM
Marc 85Z28's Avatar
That vehicle does not have an IAC.
2 things to check:
1. Clean the throttle blade and throttle body. Pay particular attention to the hole in the throttle blade. If it clogs, the idle will be very low and could cause stalling. GM issued a TSB for this.
2. Then remove the vacuum hose from the fuel pressure regulator. If you see gasoline, replace the regulator. If not, then you should be good!
Old Sep 20, 2009 | 10:52 PM
tiafn2's Avatar
Sounds like the same problem I just started having yesterday on my 02 Firehawk. Whenever I come to a stop, RPM's drop to around 1000 like normal for about 2-3 seconds and then it stalls.
transam_388
Mar 15, 2015 11:53 AM
MattFick
Feb 15, 2015 10:16 PM
DetroitZ28
Feb 13, 2015 07:33 AM
97SSdude
Dec 31, 2014 07:43 PM
cristian1311
Nov 23, 2014 02:22 PM
