Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
That p1351 icm code help please
Old Aug 16, 2009 | 11:28 AM
Dwaynez28's Avatar
Short background--I got to the guardshack at work, hit the speed bump as usual--car started to sputter and misfire , ses light flashing, barely made it to the parking lot before it died- 12 hours later, car starts ok , then about 10 minutes later it dies on the road as if i turned off the key. Waited about 15 minutes, starts, got home sputtering-- stepson pulls the codes and they were for the opti, coil and the icm--decided to throw parts at it and got a cheap coil and a icm from Oreilys--turns out it was my Jegs opti must have busted loose--got a AC/Delco now but still have the p 1351 code--icm--any ideas what may have gotten loose when i hit that speed bump? And yes sir i did the search feature and nobody hit a bump first-if that caused it--Thanks in advance. Dwayne
Old Aug 16, 2009 | 02:16 PM
Could be the white wire from the PCM to the IC Module. Could be the 12V power wire from the coil to the IC Module. Could be a faulty ground. Start with the connectors on the IC Module and the coil. Check the "A" (red) connector on the PCM.
Old Aug 16, 2009 | 06:36 PM
Dwaynez28's Avatar
Thanks for the reply/help--Dwayne
Old Sep 16, 2009 | 09:34 PM
Dwaynez28's Avatar
It was a a Bad ICM---But i think i put the coil assembly in wrong. Does anyone have a picture with all the stock stuff around the coil/ icm. It hell to get over 50--Car runs and my light is out--just want to make sure i dont create another problem later --Thanks in advance. Dwayne
Old Sep 17, 2009 | 06:38 AM
http://shbox.com/coil/coil.html
Did you use heat transfer grease under the ICM?
Old Sep 17, 2009 | 08:06 PM
Dwaynez28's Avatar
Thanks shoebox--If i remember correctly i put the three ground straps on the right side bolt and screwed it into the head-put the other bolt into the head then mounted the coil assembly on the top of those bolts-that bracket next to the intake is what got me flustered,saying i got the coil mounted right--then i just used the other nuts to lock it all down--just doesnt feel right to me. I used the grease provided with the ICM. The coil assembly is about an inch or so from the head. Thanks Dwayne
Critter
Jul 7, 2015 08:33 PM
zxtce
May 7, 2015 08:53 PM
maybe2fast
Mar 16, 2015 09:45 AM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
