Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Ebay 10.2mm plug wires.
Old Aug 15, 2009 | 07:41 PM
henryz28's Avatar
I am thinking of giving these wires a try because I think my 8.5mm msd wires are causing my car to miss. What do you guys think? http://cgi.ebay.com/ebaymotors/SPARK...Q5fAccessories
Old Aug 15, 2009 | 08:08 PM
henryz28's Avatar
Since I can't find any info on these I think I am going to go with Taylor plug wires.
Old Aug 16, 2009 | 06:02 AM
rskrause's Avatar
Moderator
Here is something I wrote on plug wires.
http://www.kennedysdynotune.com/Plug...ech%20Tips.htm
Rich
Old Aug 16, 2009 | 06:44 AM
And keep in mind that a larger diameter wire simply has more insulation on it. Adding insulation allows the system to operate at higher voltage - IF IT HAS TO (blower, nitrous) - but with the mods you show, you don't need much more than a stock 7mm wire. There's no reason the 8.5mm MSD SuperConductors won't work on your engine. If you are burning wires now, the larger diameter may just make it harder to route the wires and avoid the exhaust system. The 10.2 will not fit in the stock looms, and will be very difficult to route under the exhaust.
Old Aug 16, 2009 | 11:47 PM
henryz28's Avatar
I found that my number 5 plug wire was cooked. So I replaced that wire and all of my plugs and the car runs better but it is not 100%. I am thinking my maf is bad.
BLK1997Z28
May 7, 2015 03:01 PM
armedtrigger
Feb 24, 2015 08:30 PM
Jazsun
Dec 29, 2014 12:14 PM
