need help...timing,race gas 12psi...
Old Jul 16, 2009 | 09:06 PM
jay_rich's Avatar
OKay guys I have been running my car 7PSI for a while now on 91octane NO meth and intercooled
I am going to the track in 2 days and plan on upping to 10-12psi on racegas.(prob 100+)
What do you guys timming numbers look like?
Currently i am playing it safe 19-20* timing on 7psi.
Compression is 9.78:1.
Jay
Old Jul 16, 2009 | 09:48 PM
mzgp5x's Avatar
App... 97ss 383ci D1 MM6 ~15psi.
Timing 34* @ 90 to 100kpa
Spearco intercooler and Meth/ H20
Evans waterless coolant w/ be_cool 4 core rad. No thermostat.
Ice cold.
Old Jul 16, 2009 | 10:12 PM
jay_rich's Avatar
holy timing! whats your compression?
Jay
Old Jul 17, 2009 | 09:48 AM
mzgp5x's Avatar
9.5:1 Static (383ci - LT1 block).
JE -28cc blower pistons/ Callies/ Eagle H-beam rods/ large bearing clearances. AFR heads. LT1 uses reverse cooling (heads first). That helps, but the Evans with no thermostat is what works. Thats with a 7psi cap. Much power is lost with dial back on timing. I don't do it @ all. Another big power added is an external crank driven VAC pump. Regulated @ 1/3 atm for a wet sump. Seals the rings for more cylinder pressure, less blow-by.
All on 93 octane. B.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Apr 8, 2015 08:08 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Nostang 96z
Sep 10, 2002 08:54 PM
simple
Aug 11, 2002 11:56 AM
