Rockford RFX9300 head unit having problems!!
Old Aug 22, 2002 | 03:01 PM
slothgrant's Avatar
Angry Rockford RFX9300 head unit having problems!!
I've got a RFX9300 in my 95 Z28 that I bought for around $200 on Ebay. My local dealer wanted $450, so I took a chance and went online. Unfortunately for me, after a couple months of the unit working fine I'm now having problems with sparatic error messages about the Transverse motor (error 6), the disk not ejecting, and the unit cutting the power from one of my amps (running mids/highs). Also, the clock is reset most of the time when these problems occur, probably indicating loss of power to the unit. All this happens off and on,seems to be getting worse, and usually "fixes itself" somehow. Sometime reseting the power fixes the problem. Not sure if the problem is the the unit in general, or just if the guy I bought if from broke it. The dealer that installed the deck thinks that the problem might be a bad processor (?) or possible voltage problems with the electrical system. Have yet to test the battery/alternator, but the car doesn't have trouble starting seems to have least around 13.5 volts on the gauge at idle/cruise/ect. What do you guys think? Want to make sure before sending the unit to Rockford for repair .
Black 1995 Camaro Z28- http://www.geocities.com/slothgrant/95Camaro.html :
T56 6-speed, cold-air intake, Hypertech 160 Powerstat, Hypertech PP+, 1LE intake elbow, Borla exhaust, FilterMag, BMR full suspension: (strut tower brace, rear control arms, torque arm, panhard bar, sway bars, and subframe connectors), Eibach Sportline springs, KYB rear shocks, 3.73 gears, Detroit locker, Centerforce Dual-Friction clutch, Lou’s short stick, CAGS eliminator, SLP manual fan switch, Dayton Daytona ZR 245/50/16 tires, SS hood, shaved handles, Rockford Fosgate RFX9300 head unit, 12" HX2 sub, JL Audio 250-watt amp, white face gauges.
Rod Bender
Jan 1, 2015 03:18 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
ezcheeze15
Aug 26, 2002 01:28 PM
Timberwolf
Jul 20, 2002 08:45 AM
Absolute Z28
Jul 19, 2002 02:21 PM
