E-brake light wont go away
Old Jul 6, 2009 | 02:32 PM
Kredz28's Avatar
Pretty self explanatory,but my e-brake light wont turn off on the dash. When e-brake is disengaged, the light stays on. Any ideas how to make it go away?
Old Jul 6, 2009 | 03:22 PM
brianswimmer23's Avatar
and you have made sure you put the ebrake all the way down and wiggled it into place?? sometimes i have to push the button in and go all the way up and all the way down to get the light to go off in my wifes car 01 rs.
Old Jul 6, 2009 | 04:13 PM
Kredz28's Avatar
Messed around with the handle, and nothing has taken the ebrake light away...any other ideas?
Old Jul 6, 2009 | 05:16 PM
Wrong forum, since its not an "engine" question... but I'll answer the question before I move it to the correct forum.
The "BRAKE" light serves 2 different purposes. Obviously its for the E-brake. But it also comes on if you have unequal pressure in the front and rear braking systems. Could mean you have a leak in either the front or rear, air in the system, etc. The light is activated by the pressure switch in the block attached to the right side of the ABS motor pack.
Old Jul 6, 2009 | 05:35 PM
Kredz28's Avatar
thanks for the information. It makes sense, seeing as how my brake pedal is a bit stiffer than normal. Do i need to bleed the brakes?
Old Jul 8, 2009 | 10:57 AM
shockguys's Avatar
Could also be the simplest of things such as the fluid level. But if your pedal is 'stiff' could be a pressure issue.
Check the fluid level, make sure it's not low first.
Old Jul 8, 2009 | 05:51 PM
Low fluid will only turn on the "BRAKE" light if its so low that air got in the lines. There is no level sensor on the reservoir.
Old Jul 13, 2009 | 09:22 AM
multicar's Avatar
there's a brake light switch at the e-brake lever...might need an adjustment.
Old Jul 14, 2009 | 03:27 PM
Kredz28's Avatar
Got my brake system flushed and fixed the problem
dluna333
15
Mar 13, 2015 12:30 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
