What is this wire?
Old Jun 29, 2009 | 09:42 PM
SmokeyBlaZe's Avatar
What is this wire?
started to take my pcm out and noticed this loose wire. Any Ideas what it is?
Old Jun 29, 2009 | 10:04 PM
http://shbox.com/1/fuel_pump_prime.jpg
Old Jun 29, 2009 | 11:06 PM
Why would it be unplugged?
Old Jun 29, 2009 | 11:11 PM
Im having a problem with my 95 z28 I just purchased , I have narrowed it down to 3 or 4 things that I think could be possibilities. 1. Pcm Needs to be tuned. 2. Optispark needs replaced/fixed 3. Clogged Cat-Converter or 4. bad plugs and wires.
but I saw this and thought I would find out why its unplugged and If it may be causing my problems.
Old Jun 30, 2009 | 05:15 AM
Because its only used to supply temporary power to the fuel pump, bypassing the pump relay and the PCM permits, to test the fuel pump. There is no matching connector to connect to it. You run 12V power from the battery to the connector to test the pump.
Old Jun 30, 2009 | 05:17 AM
Describe the "problem" you are trying to solve. Without knowing that, its pretty hard to point you in the correct direction.
Old Jul 2, 2009 | 06:59 PM
How about a video? Wouldn't that work better?
Old Jul 2, 2009 | 10:20 PM
Not without some description of the problem.
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
