JBL 1200.1 amp to power 10" L7 solo baric? (older solo)
Old Aug 15, 2002 | 02:09 PM
Omega9's Avatar
Question JBL 1200.1 amp to power 10" L7 solo baric? (older solo)
I've decided to go with the JBL 1200.1 amp to power my dual 4ohm 10" L7 solo baric (older model). I'm going to put it in a smaller box and just turn the gain down. What do you guys think? If possible, please respond quickly because i'm ordering everything in a short while. thanks
Omega9
97 black Camaro coupe 3.8v6 (loaded)
NX Nitrous system(75hp shot)
Bridgestone Potenza 235 55 r16 tires
K&N
GTS carbon fiber blackouts (rear)
GTS smoke blackouts (front)
red neon license plate border
20 limo tint
System: 10" Kicker L7 Solo Baric,(waiting for new cd deck and amp)
hot chicks with big ***** option
Dad's Ride
91 white convertable Corvette 6 speed
3 way adjustable suspension
Old Aug 15, 2002 | 02:14 PM
camaudio's Avatar
Post
yeah, that amp will work good with the sub, just watch the gain levels, cause you COULD blow the sub if you crank it to much.
also, make sure the amp has good ventilation, those amps like to get warm
Old Aug 15, 2002 | 02:47 PM
Omega9's Avatar
Thumbs up
Thanks for the quick reply! Ordering the JBL 1200.1 now.
Old Aug 16, 2002 | 01:13 PM
Polecat's Avatar
Post
It will work...little overpowering though. The JBL 600 would be a better fit...unless you plan to add another for the JBL 1200.
Speed-O-Motive 383 stroker kit,4 bolt 350 bored .030 over,TRW Forged pistons,Moly Rings,Comp Xtreme 284 cam,.540 lift with Crane 1.6 roller rockers,World Products Sportsman II heads, ported and polished with 2.02/1.60 valves, Comp guideplates,Edelbrock RPM intake,Holley 750DP carb,Hedman 1 5/8 headers to 2.5" duals and flowmasters,HEI with MSD6A box,TH350 with Hughes 3000 stall,4.11 gears.
Old Aug 17, 2002 | 01:20 AM
Omega9's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Polecat:
</font>
I'm going to have it in a small box. I'll turn the gain down. My sub is a dual 4 ohm.
Old Aug 17, 2002 | 04:23 PM
redz_02's Avatar
Post
Well i am putting a orion xtrpro 1000 to my L7 12". It will work but you might blow it. Just when you hook it up don't turn it up all the way and you will be fine. But 2 10's for that amp would be better. Plus on the gain don't use it as a volume conrtol, it is used to match the voltage from your pre-amps in you head unit.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
Borla (the expensive cut-out), Wisperlid W/K&N, FRA, Cags eliminator, Strange 4.10's, G2 Rear Girdle, Valv. Synthetic 10W-30, Redline gear oil, Fat hurst shift ****, Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev K2's, Focal utopia 6" audiom midrange.
Omega9
Aug 14, 2002 10:59 PM
Omega9
Aug 2, 2002 12:33 AM
XtremeLt1
Aug 1, 2002 11:25 AM
Omega9
Jul 20, 2002 05:46 PM
Omega9
Jul 20, 2002 06:09 AM
