Failed Smog, Please help.
Old Jun 15, 2009 | 04:17 PM
sobo's Avatar
305 tpi. High miles
Here's the readings.
HC (ppm)
max 110 meas. 160
no (ppm)
max 772 meas. 938
What do you guys think?
I should also say that I did not drive it on the weekend and took it in this morning for smog after driving it a short time. Is it possible I didn't heat the cat up enough?
Thanks for the help
Old Jun 15, 2009 | 11:37 PM
SupplySgt.'s Avatar
it is possible that you didn't heat it up enough. however I'm not sure if it would make that huge of a difference. I would check everything from the intake system to the fuel system to the sensors if you're getting high readings in everything. If it was one or the other I could narrow it down for you but it's not.
Old Jun 16, 2009 | 08:18 AM
sobo's Avatar
I need to point out that all of my other readings were within limits. These readings that failed are at 15mph.
Old Jun 18, 2009 | 01:20 PM
Gtpguy's Avatar
Have you done a full tune up yet? Cap, rotor, wires, plugs, o2? Are there any SES lights?
Old Jun 22, 2009 | 11:18 PM
Tex95Z's Avatar
Could use a little more info about your car, mods and such.
Kinglouui
May 26, 2016 11:05 AM
David Dempsey
Mar 12, 2016 12:42 AM
truecontr3
Oct 11, 2015 09:30 AM
surreybrad
Sep 29, 2015 09:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
