Can a dual voice coil woofer be bridged?
Old Aug 9, 2002 | 12:08 PM
Skull Leader's Avatar
Question Can a dual voice coil woofer be bridged?
I was reading somewhere that it is not a good idea to do that. I have 2 Audiobahn 12" AW 1200Qs that have been sitting on my floor since March. Now I have the funds to get a semi decent amp like a JBL or Lanzar. What do you cats think?
Skull-1 1997 Formula VF-1S
Protoculture:
OBD II LT1 Edit test subject #2, A4 with Motive 3.42s, LT4 Hotcam, G2 LCAs, Hotchkis panhard rod, real Bilstein shocks, Eibach Pros, Flowbastard muffler, ported + polished MAF, Mocoso CAI, Hypertech 160 thermo, TB bypass & airfoil, 1LE sway bars, poly bushings all over, exhaust cutout, BMR STB, 1997 17x9 SS wheels, NKG plugs, big block hood, BBK headers, Jacobs wires, Walbro 255 fuel pump, NX afterburner, times and ET not worth mentioning at 4000ft
I'll chisel your gravestone... sleep well
http://skull-leader.cz28.com
Old Aug 9, 2002 | 12:23 PM
LS1 RULZ's Avatar
Post
No, you cannot "bridge" a speaker. Bridging is a function of a 2 channel amplfier.
You can either connect the VC's in series or parallel.
Old Aug 9, 2002 | 12:30 PM
ChameleonGreen's Avatar
Post
Those Audiobahns probably have dual 4-ohm voice coils. If that is the case, then you will want either a mono class d amp that puts out max power at 1ohm. Or, a 2ch amp that puts out max power when bridged at 4ohms. For the first one you would wire them in parallel, for the second option you would wire them in series-parallel.
If the subs do not have dual 4ohm voice coils, disregard this.
Old Aug 9, 2002 | 12:31 PM
camaudio's Avatar
Post
im pretty sure those subs are DVC 4 ohm, so if you wire that all in parallel, you get 1 ohm.
there are a few 1 ohm stable amps out....
MA audio Class x and HIgh Current
Orion XTR Pro (even though they dont claim it)
earthquake PHD2
DEI 1100D
theres some others that are good
or you can get a 2 channel, and run 2 ohm stereo or 4 ohm bridged
Old Aug 9, 2002 | 12:40 PM
LS1 RULZ's Avatar
Post
With two 4ohm DVC subs your wiring options are...
1) VC's in series and subs in parallel for a 4ohm load. (4ohms + 4ohms)//(4ohms + 4ohms) = 4ohms
2) VC's in parallel and subs in parallel for a 1ohm load. (4ohms // 4ohms) // (4ohms // 4ohms) = 1ohm
+ = series connection
// = parallel connection
[This message has been edited by LS1 RULZ (edited August 09, 2002).]
Old Aug 9, 2002 | 12:59 PM
camaudio's Avatar
Post
(4ohms + 4ohms)//(4ohms + 4ohms) = (4ohms)
so now one gets confused
Old Aug 9, 2002 | 02:34 PM
redz_02's Avatar
Post
You can wire them so that they bridge the amp. Act as if they are 4 speakers instead of 2. I wired my 4 ohm DVC type R's in my old system to bridge the amp. I paralleled the load of each speaker to 2 ohms and then seriesed them together to 4 ohms in on channel. You want to bridge subs so they run mono and hit at the same time. In stereo you won't get as much output.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
Borla (the expensive cut-out), Wisperlid W/K&N, FRA, Cags eliminator, Strange 4.10's, G2 Rear Girdle, Valv. Synthetic 10W-30, Redline gear oil, Fat hurst shift ****, Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev K2's, Focal utopia 6" audiom midrange.
Old Aug 9, 2002 | 03:28 PM
LS1 RULZ's Avatar
Post
Thanks for the heads up Camaudio. Sometimes I type faster than I think. LOL
One last time...
YOU DO NOT BRIDGE SPEAKERS!
Old Aug 9, 2002 | 06:23 PM
jdohman's Avatar
Post
Run the coils not in parrell mode then run the amp bridged to the two subs.. That should give you a 2 ohm load
Old Aug 10, 2002 | 04:41 AM
Lightbulb
OK so maybe you don't bridge speakers. I was just wondering what would happen if I bridge a 4 channel amp to drive the 2 speakers @ 2 ohms, or something like that. I was trying to decide to get a 2 or 4 channel. Thanks for the advice.
Old Aug 10, 2002 | 04:47 AM
redz_02's Avatar
Post
If you want to that would work. You just have to find out the resistance that the amp can be bridged at. Say on a 4 channel you bridge to 2 channels at 4 ohms. Then you would have to have 2 or 8 ohm DVC speakers so you could wire the resistance to 4 ohms.
Soon to be:
Old Aug 10, 2002 | 10:30 AM
john-e-boy's Avatar
Post
What do you mean by parallel vs. in sreies?
can someone explain in rookie terms, I have a set of fosgate DVCand they have connectors on each side, so how would you hook them up parallel and how would you hook them up in series?
Sorry for the rookie ?
John
Old Aug 10, 2002 | 11:01 AM
LS1 RULZ's Avatar
Post
Go to www.jlaudio.com and read their "Tutorials". That should tell you all you need to know about series and parallel connections.
bunker
Aug 21, 2015 10:21 AM
zajones
Jul 30, 2015 02:18 PM
Jlo
Jul 29, 2015 03:52 PM
Catmaigne
Jul 14, 2015 05:17 PM
mrwz28
Jul 8, 2015 09:11 PM
