Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
LT1 Losing power at high RPM
Old Jun 4, 2009 | 01:54 AM
Sergey's Avatar
I recently bought a 94 LT1 Camaro that has 60k miles on it as of now. The only performance mods I have done are intake and catback.
If I press on the gas all the way and go up to red line, about one quarter of the time the car seems to accelerate normally. The other three quarters of the time the car seems to "let of the gas a bit" the last one thousand RPM before it hits red line. Its almost like Im taking my foot off the pedal just a little bit. Also there seems to be power loss at around 2k rpm sometimes even when I dont floor it. Its like that infamous LT1 torque doesnt want to show up for work sometimes. Lately Ive also been smelling gasoline when I drive with my window down.
I dont know if any tune ups have been done to this car like wires and plugs. The only thing I know that has been replace was the fuel filter half a year ago when I bought the car. Ive also used fuel injector/fuel system cleaners about 4 times since I bought the car and I vary the type of gasoline grade I use. Im wondering, could the fuel filter have clogged up prematurely? I really hope its not the fuel pump since the miles are pretty low on this car and it seems to have been taken care of pretty well before I bought it.
Can someone point me in the right direction on what I should start checking?
Old Jun 5, 2009 | 09:09 AM
josh77888's Avatar
Im going thru the same thing right now, What type of fuel filter did you put it in? You get what you pay for.
Also do i fuel pressure test, check FPR for fuel in the hose and check for leaky injectors.
I would also recommend a tune up if you havent done one.
I also wouldnt recommend those fuel system cleaners, from personal use i noticed they would foul out my plugs. Could have been just me though??
Old Jun 5, 2009 | 11:50 PM
You indicate you vary the gasoline grade. Does the loss of high RPM power correlate to using low octane fuel? If so, might be a problem with knock retard.
Old Jun 6, 2009 | 02:27 AM
Sergey's Avatar
Lately I have been using the cheap fuel more often than not. I will fill it up with premium next time and do some acceleration tests. Thanks for the help.
Old Jun 24, 2009 | 10:39 PM
maddog05's Avatar
I think you need a new fuel filter...Purolator ... it is a cheap remedy and may work. U se high test.
Old Jun 25, 2009 | 12:33 AM
lbrowne's Avatar
I think you really need to put what the car really wants in the tank - premium. I'm with Injuneer on this one.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
rideordie
Nov 5, 2019 04:52 PM
Lions3
Aug 18, 2002 11:12 AM
