315's in rear, yes or no?
Old Jan 14, 2003 | 05:06 PM
Michael Ozorowsky's Avatar
Hey guys, I found some 17x11 ZR1 rims on tbyrne.com, and was wondering if I should run into any problems running these rims? I want to get 315's in the rear, to improve traction. Check out my web site at www.cardomain.com/id/ozorowsky for list of my mods. What do you think? Thanks.
Old Jan 14, 2003 | 07:50 PM
2002 NBM Bird's Avatar
With the proper off set and hammering some part in, you'll be fine. A lot of guys run that kind of setup.
When my tree starts growing money in the spring, i'll be shooting for a set of TT2 in 17X11 and chrome!!!!
Old Jan 14, 2003 | 08:48 PM
Mikael's Avatar
DO IT!!!
It really looks good. I have the same setup. I could get you some pics if ya need em.
Old Jan 15, 2003 | 12:38 PM
PAGregSS's Avatar
I've had zero problems with mine and I just bolted mine on and went on my merry way. I don't even have to jack rear by the axle. I have enough clearance that the car can go up on a regular lift and the wheels go on and off with no problem.
Old Jan 15, 2003 | 04:30 PM
vendela99's Avatar
My 99 Z required hammering, and my 98 SS did not, so it's kind of luck of the draw as with a lot of things on these cars. It's well worth your effort though for looks and traction both.
Old Jan 15, 2003 | 05:47 PM
Would you guys say putting 315's helps with traction a lot? A friend of mine says that it won't help that much. Traction would be the main reason I would want them, and how would it raise the rear of the car up higher? If anything, I thought it would be lower going with a 35 tire. Correct me if I'm wrong, thanks.
Old Jan 15, 2003 | 05:52 PM
Ken S's Avatar
what offset did you run?
Old Jan 15, 2003 | 05:58 PM
vendela99's Avatar
traction depends on what tire you run...if you run a nitto...treadwear 100A...or even better, a Yokohama a032r...treadware 60...or any other tire thats that soft then hell yes your traction will be better, but if you just run a regular tire then no, you'd probably get better traction with just a set of drag radials. also, this is not going to make your any higher in the back.
Old Jan 15, 2003 | 07:08 PM
psychocabbage's Avatar
but keep in mind that you are adding enough tire that you may add too much friction and not see much of a gain from them..
I would suggest against them seeing as how I have seen people with 400 rwtq numbers get traction out of 245's (pulls 1.7's all day long)
I think its personal preferecne.. I like stock looks, others like the mega tire look of the 70's.
Old Jan 16, 2003 | 04:09 AM
chesee48's Avatar
i love the 315's in the rear! i'll never go back to anything smaller!!!
Old Jan 16, 2003 | 04:15 AM
stik6shift98's Avatar
hell yes........
96SilverRam
Nov 20, 2016 11:19 AM
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
thenewkid
Apr 12, 2015 07:42 PM
