Guys running Hooker LTs w/ Borla get inside
Old Jan 14, 2003 | 04:08 PM
BadBwty's Avatar
Im installing Hooker LTs this weekend. My plan is to run the LTs w/ no cats with my adj.Borla catback. My question is what plate on the Borla are you using. Im thinking the one w/ the smallest hole. Tell me what you think.
Old Jan 14, 2003 | 04:34 PM
Tranny95's Avatar
i have a set of tpis longtubes on my car with no cat. when i installed the headers i had the wide open plate on mine. it was really loud, which is cool but i changed it to the smallest and it still sounds good.
Old Jan 14, 2003 | 06:29 PM
ShelbyZ28's Avatar
I also switched from the largest to the smallest holed plate when I had my Borla. The smallest plate seems to be the best for this setup. Enjoy the LTs!
Bryan
Old Jan 14, 2003 | 06:46 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
I use to run the smallest, but would whicth to the closed one on long trips or if I got sick of the noise level. My new combo will be in next week with Hooker-long tubes. I dought it will be any louder than with my Mac header with Off-Road y-pipe.
Old Jan 14, 2003 | 07:01 PM
americanmuscleman's Avatar
I run a closed plate on mine. Its definitely still really loud at WOT, but sounds "clean" in the midrange. I'm running without a cat by the way.
Old Jan 14, 2003 | 08:02 PM
funina91ss's Avatar
I dont know how loud yours is now but I was running the smallest whole and it was loud I now have the 2nd largest one in just too hear it even more I only got to drive it one day like this trans started slipping I bet when I get the 3000 stall in I will have to block it off
To answer your???? I would start big and step down untill you like it the best.
Old Jan 14, 2003 | 08:05 PM
BadBwty's Avatar
Thanks for all the replies i think i will start big until i find the sound im looking for.
Old Feb 18, 2003 | 01:06 PM
TonyJ's Avatar
If you want to sound NASCAR, run without the plate...
I use the smallest hole plate and it ranges from loud to NASCAR at WOT. The idle is wicked...
Old Feb 18, 2003 | 02:03 PM
KCFormula's Avatar
A good friend of mine has a '96 Ram air, with Hooker LTs and Borla. We both have the smallest hole plate in and his is a lot more quiet than mine. I think its because the Hooker LTs are equal length where as the FLPs are not. Therefore more bends in the Hookers to dampen sound.
There is a fair amount of rasp with the pass side open at all, however most of it goes away when you put the full block off plate in.
Old Feb 18, 2003 | 04:56 PM
funina91ss's Avatar
go to the link that says video's of the 95 to here mine I got the stall in and still have the 2nd largest plate in.. watch the laucnh video and listen to the sound real good you can hear it from a mile away...
Old Feb 18, 2003 | 05:26 PM
ZaneO's Avatar
I was wondering if the LT's will make much sound difference (loudness) over my current set up of off road y-pipe and Borla?
Not trying to hi-jack your thread.
Jan 5, 2015 07:14 PM
ModdedNerd
Jan 1, 2015 10:56 AM
squarehead
Nov 21, 2014 08:02 PM
sleeperZ96BT
Aug 16, 2002 02:24 AM
Red97LT1
Aug 7, 2002 05:45 PM
