out of the usual problem
Old Jun 1, 2009 | 02:06 PM
oneclean97z's Avatar
First off I haven't been on in a good while so what's going on everybody? Here's the problem. Both front brake discs have been warped and wobble when i brake, its even worse the faster I'm going but I have ignored it for some time. Recently I changed my brake pads with a buddy mechanic on all four wheels. Back ones were completely toasted even metal was gone somewhat. So brand new pads on all fours. About a week later I started hearing this "tap" noise coming from front left wheel and it goes with my wheel speed so faster as I'm traveling faster so on so forth. Funny thing is it completely vanishes when I hit the brakes. Everytime. Sometimes the noise isn't even there and that's usually before the car has warmed up which is even stranger. Took wheel off today, everything looks fine, no loose bolts no nothing. I plan on taking the discs off and up to o'reilly to have them re-surface them but not sure what that may do. Does anyone have any ideas or input? It would go a long way if so
Old Jun 1, 2009 | 03:44 PM
n2ceptor's Avatar
Instead of spending 10 each on turning, by new for 25~30 each...
Old Jun 1, 2009 | 07:40 PM
I'll do either one of those here in next few days. Any ideas out there that pop into anyone's head though?
Old Jun 1, 2009 | 10:11 PM
Could be a warped rotor - as the high spot hits the pad, the pads hits against a part of the caliper. Did he get the retainer spring clips fully engaged?
Are you saying your pads were so worn out that you were wearing out the steel backing plates, but you just kept the gouged rotors?
Old Jun 8, 2009 | 01:05 AM
well the back pads were the ones that were over-gone. the front rotors are the ones that are warped. now the front pads were just about gone however. still havent done the discs yet but i will keep you guys updated. also i am noticing that the tap is not there until i have driven a lil or basically by the time the motor has warmed up. weird huh?
Old Jun 8, 2009 | 01:25 AM
Angelis83LT's Avatar
I wonder what driving with a set of warped rotors for a prolonged period may do to the wheel bearings.
Old Jun 22, 2009 | 10:08 PM
well still haven't gotten around to doing anything lol. yeah like i said the tap noise only is noticeable when the car has been driven a lil bit, around the time the motor has warmed up actually. and it completely vanishes once even a tiny bit of brake pressure is applied. very strange. ill get to it soon i promise
Old Jun 23, 2009 | 06:01 AM
ws6transam's Avatar
A twelve year old car with pulsing brakes should always include new rotors. They are only a few dollars more than the cost of resurfacing.
Old Jul 21, 2009 | 01:04 AM
okay update lol still haven't used swapped the rotors yet, haven't used car too much anyways, but will be doing it within the next few days. i'll let you guys know how the noise problem goes afterwards
Old Jul 23, 2009 | 02:57 PM
okay so i swapped the rotors and everything is back to normal! no more tap noise, no more wobble when braking, no more slightly slipping when its wet outside! i was expecting the tap to be something else like something caliper related but it was the rotors all along, after all i did drive it everyday with them warped for almost a year lmao. just letting you guys know how it ended up
Old Jul 28, 2009 | 10:45 PM
WestCoast96Z28's Avatar
Good to hear the board came through for you. That's what we're all hear for...sharing experience on our rides.
Congrats on your fixing your issue.
Bxlt1
18
May 27, 2015 05:00 PM
99TransAmWS6
Mar 23, 2015 12:02 PM
Catmaigne
Dec 25, 2014 12:16 PM
slothgrant
Aug 22, 2002 03:01 PM
