speedo issues....urghhh
Old May 22, 2009 | 08:06 AM
crash4cyl's Avatar
So My 93 has one issue. The speedo shows I'm going 10-40 mph when I'm standing still. Weather the caris in park or in gear the speedo registers a speed while not moving. Now I've already tried the speed sensor, and even a cluster. Unfortunately neither of these have cured the issue. Anyone have any ideas?
Old May 22, 2009 | 01:43 PM
josh77888's Avatar
my 93 wouldnt register at all sometimes i just slap the dash with my hand and everything is fine. idk try doing that it might help you out as well.
Old May 22, 2009 | 04:43 PM
crash4cyl's Avatar
I've been tempted to put my hand through the damn dash! I've been so agitated with this as of late, the biggest thing is it just keeps racking up some miles and I'd like to keep it low as it is.
Old May 22, 2009 | 05:17 PM
If replacing the VSS and the cluster didn't solve the problem, it has to be a wiring problem. The 93 is a bit different than the 94 and newer models... I believe the VSS connects to both the ECM and the speedo. Something may be inducing a pulse signal similar to the pulses from the VSS.
Old May 22, 2009 | 08:20 PM
crash4cyl's Avatar
the vss sends the signal to the ecm then to the dash from there....My only guess from here is a ground, the question is which one??? I was hoping that someone has had a similar problem, but I guess it's not a common thing....I guess I'll just start by checking every ground I have...As a side note, the battery must be getting old, since the voltage gauge starts out up around 16 volts, then after driving awhile drops back down to 14....urgh I love the first model year cars
Sep 27, 2015 01:55 PM
mmf_1013
Sep 12, 2015 08:56 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
LazyLemming
Aug 29, 2015 07:36 PM
4586
Aug 24, 2015 11:04 PM
