block off plates
Old May 12, 2009 | 07:29 AM
tomsws6's Avatar
block off plates
ok i put in the longtubes but now have those hoses for the air layin around. i think theres 2 up front (rubber) that went to both passenger side and driver side headers and looks like a hard flexible brass one in the back. i heard that i need egr block off plates. someone point me in the right direction? I should have my ypipe by the end of the week and would like to be done with the exhaust. thanks
Old May 12, 2009 | 08:02 AM
josh77888's Avatar
ebay will have all your answers.
Old May 12, 2009 | 03:20 PM
johnny6's Avatar
There you go http://search.ebay.com/search/search...tes&category0=
I made my own in about 10 minutes.
Old May 18, 2009 | 05:27 PM
6SpdLT1Z's Avatar
He has a '97.
GM p/n 10054880 "LT4 Block off Plate"
or
http://www.randdspeed.com/index.php?...roducts_id=181
Old May 19, 2009 | 12:18 AM
The connections that went to the front of each exhuast manifold are the AIR supply lines. You remove the AIR pump, and the only things you have to block off are the AIR pump air supply line nipple on the inlet air ducting (5/8" ?? vacuum cap), and put small vacuum caps on the vacuum line to the AIR pump system (what you have will depend on whether your car had the AIR pump "recall" work done). Courtesy of Shoebox:
http://shbox.com/1/air_pump_recall.jpg
The flexible tube on the back of the intake manifold ran from the #8 runner on the passenger side manifold to the back of the intake manifold. You can just get (or make) a single, diamond-shaped block-off plate to cover the hole in the back of the intake manifold. If you want to delete the EGR valve, you need a second block-off plate, like the one's shown in the link above.
If you remove the EGR valve, then you remove the EGR vacuum solenoid. That requires that you put a vacuum cap on the vacuum nipple on the driver's side of the intake manifold.
http://shbox.com/1/egr1.jpg
Now you have to address the PCM codes that you will get for deleting the AIR and EGR components. Easiest thing to do is have the diagnostics "programmed out" of the PCM. If you have an emissions check where they plug into the ALDL connector, make sure the programmer knows how to delete the codes, without causing the PCM to set a "system not ready" flag. In some inspections, they will not pass you with too many "not ready" flags.
[EDIT] Why do I have the feeling that I just typed the exact same answer I gave you on another site?
Old May 26, 2009 | 09:26 PM
tomsws6's Avatar
actually you did. i posted it on a couple forums one after the other. i love your detailed anwers
Quickss96
Jan 29, 2016 05:56 PM
RobFlag
Aug 29, 2015 11:40 PM
Cbr02
Aug 24, 2015 07:12 AM
karpetcm
Aug 14, 2015 03:02 PM
Jlo
Jul 29, 2015 03:52 PM
