Are C4 and C5 brake adapters the same?
Old May 10, 2009 | 08:24 AM
RobsWS6's Avatar
Back when I did my brakes, over 10 years ago, I used 13" C4 brakes and an adapter to make it work. Basically a Baer setup without the expense.
Having been out of the LT1 scene for so long and now seeing that C5 conversions are the big thing. Are the adapters the same? The braking is still much better than stock but always could be better
Old May 11, 2009 | 07:08 AM
NJ-LE's Avatar
robsWS6:
I installed this setup: http://www.umiperformance.com/produc...item_id=212022 They are 13" rotors. The link will provide a reasonable look at the parts, including the brackets, calipers and rotors. I assume the only difference might be in the calipers.
Old May 12, 2009 | 05:49 AM
RobsWS6's Avatar
Thanks. That is pretty much the setup I want if I do it again. I'm just wondering if the adapters are the same to run those calipers.
Boss002
Jul 24, 2015 10:47 AM
whitehooptie
Jul 22, 2015 10:25 PM
whitehooptie
Jul 12, 2015 06:10 PM
