What other years fit a '95???
Old Apr 21, 2009 | 10:18 PM
Silasgore1's Avatar
I'm new here so please be gentle with me
What year rims will fit the '95 coupe? I have been told 93-97, true or false?
Any help welcome!
Tim
Old Apr 21, 2009 | 11:13 PM
All 4th Gen (93-02) wheels are interchangeable, coupe or convertible, with one minor exception. The rear axle hub diameter on the 93-96 cars is larger in diameter than the front hub, and larger in diameter than the front and rear hubs on the 97-02 4th Gens. As a result, to fit 97 or newer wheels on the rear of a 93-96, you may have to lightly sand/grind the inside diameter of the rear wheel hub holes to allow them to fit over the hubs. This has no negative affect on the wheel, or its installation.
You can also use Corvette wheels from 84-09. They have the same bolt circle. But they often have excessive "offset" which puts them too deep in the wheel wells. But there are many specific Corvette wheels that will fit without modification, there are bolt-on adapter/spacers, and there are aftermarket reporductions of most Corvette wheels that are made in offsets that work right on 4th Gen F-Bodys.
The 3rd Gen F-Bodys have the same bolt circle as the 4th Gens, but they have very small offsets, which usually puts the wheel/tire outside the fender line.
Old Apr 21, 2009 | 11:17 PM
Silasgore1's Avatar
Thanks for the info!!!
Old Apr 22, 2009 | 10:10 AM
ahhwataday's Avatar
You looking for some stock wheels? I have 4 sets if you're interested
Old Apr 22, 2009 | 03:52 PM
Silasgore1's Avatar
Naw, I would like to throw a set of chrome rims on it and just use the stock rims for winter use.
Tim
HectorM52
Jun 23, 2016 08:42 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Jan 23, 2015 01:13 PM
ANDYZ28
Dec 29, 2014 09:13 PM
