Access to top rear shock bolts??
Old Apr 9, 2009 | 06:25 PM
I8ASTNG's Avatar
I tried searching but found nothing! I really need this car driving tonight, both my rear shocks are seized the car drives like a dump truck right now, bounces all over the place.
Thanks!
Old Apr 9, 2009 | 09:06 PM
bluz28's Avatar
Thumbs up
Fold the rear seat down and look for perforations in the carpet on each side that are in a U shape, once you find them use a utility knife and cut along the perforations until you have a U shaped flap. You'll also need to cut out the carpet insulation beneath that, then just pull out the light yellow foam rubber piece above the shock.
Old Apr 10, 2009 | 12:36 PM
Bud M's Avatar
You don't have to cut the carpet, you can remove the plastic panels in the rear and lift the carpet out of the way.
Old Apr 10, 2009 | 05:15 PM
I just pulled the carpet up and pulled out the foam rubber inserts that fill the holes over the upper shock nuts. No cutting, no panel removal.
Old Apr 12, 2009 | 09:38 AM
Lol, cut the carpet? That is a bit extreme.
Old Apr 12, 2009 | 10:15 AM
Rob... you and I did the shocks at the same time (was is around 1998?). Did you do anything different than I did? Is my writeup on shock replacement correct? I don't remember it being all this complicated.
Old Apr 12, 2009 | 12:48 PM
bluz28's Avatar
Wink
Not really, you're just cutting a U shaped flap in the carpet.
The first time I changed the rear shocks(2000) I noticed the perforations in the carpet above the rear upper shock mounts, so I cut along them. Now access to the mounts takes just seconds, and if you have Koni SAs, or DAs adjusting the shocks is a lot less of a hassle.
Old Apr 13, 2009 | 06:45 AM
Pretty much the same, I would say. As far as access to the back, I remove the back, side panels to make the carpet work a little easier. Nothing too complicated on the rear.
Old Apr 21, 2009 | 07:55 AM
Capn Pete's Avatar
Just cut the flaps and be done . It's really NOT a big deal!
Old Apr 21, 2009 | 11:42 PM
Different strokes for different folks
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
siguy
Nov 27, 2014 10:07 AM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
slothgrant
Aug 22, 2002 03:01 PM
