Low Track light !
Old Apr 23, 2009 | 10:08 PM
mannycamaro's Avatar
From: San Juan Puerto Rico, Look it up it's in the Caribean
Low Track light !
Hello, Guys !
I am having some trouble with my car. When I aply the brakes the low track light come on, and then the pedal goes complete down. Also it brakes more from one side than the other.
This is the first time that I have an issue with my brakes. Does this means that I have to change my brakes pads ???
I hope you can help me...
Old Apr 23, 2009 | 10:23 PM
Z28Freak86's Avatar
Warped rotors is my best guess... check ur pads and ur rotors. replace the pads if they are low or have uneven wear, then see if the rotors are still straight.
Old Apr 24, 2009 | 05:14 AM
The "LOW TRAC" light indicates your ABS system has activated. If you are not making hard stops, or on a gravel surface, or going over a bumpy patch, the ABS should not be engaging. If its activating every time you stop, its most likely a more severe problem than worn pads or warped rotors. Get the entire braking system checked.
Moving to correct forum.....
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Feffman
Oct 9, 2015 05:42 AM
Jan 23, 2015 01:13 PM
