Anyone with subframe connectors and the STS kit?
Old Apr 7, 2009 | 10:20 AM
Tokuzumi's Avatar
Anyone out there with the double diamond subframe connectors, and the STS kit? STS indicates their kit is not really compatible with the double diamonds, but wanted to see if this is a big deal.
Old Apr 7, 2009 | 11:28 AM
jsetzer's Avatar
I don't have direct experience with this, but here are my thoughts.
The double diamonds eat up a couple of inches under the car. The sts kit would work but the pipes may have to be run lower. Meaning you may need a few bends to get it to curve under the connectors.
You can probably figure out the points where the pipe goes under them. Take a tape measure and see how much 2.5" or 3" (whatever sts runs) pipe will sag to clear them.
Old Apr 7, 2009 | 11:11 PM
MikeGyver's Avatar
Depends on the year of the F body and such, but the pipe runs down the little "channel" near the rocker.
Old Apr 7, 2009 | 11:44 PM
Tokuzumi's Avatar
Mike,
Thanks. What is the size of that pipe? Also, do you have any profile shots of the underside of the car, with it on the ground?
Do you have headers? Looks like longtubes. What brand? Also, are you lowered, or stock ride height?
Old Apr 8, 2009 | 12:23 AM
MikeGyver's Avatar
That's not my car, It's just a pic I found on Google.
The pipe is 2.25" though.
I built my own pipes for my STS kit so they're a bit different and higher clearance. My charge pipe runs down the tunnel till it gets to the transmission, then it kicks over to the driverside and goes over the K member along the engine, then off to the intercooler.
If you had to, you could always build your own center pipes in order to clear the bracing.
Old Apr 8, 2009 | 12:39 PM
Tokuzumi's Avatar
Mike,
Thanks again. What about your headers? Are they longtubes, and if so, what brand? How is the ground clearance on those babies?
Old Apr 9, 2009 | 02:33 AM
MikeGyver's Avatar
Stock manifolds. Exhaust is all stock.
Headers probably wouldn't help with a rear mount turbo as the exhaust gas all gets mixed up anyway.
Old Apr 14, 2009 | 04:09 PM
QuickdomesticRacer's Avatar
Mike any more pictures of your setup?
Where do you tap for the oil feed/return on the LT-1's?
Old Apr 14, 2009 | 08:44 PM
MikeGyver's Avatar
Oil is taken from the 1/4" NPT plug in the block near the oil filter, and returned to the valve cover.
The STS kits return oil through the oil fill cap with a quick connector, so no modification is required.
I welded a 4AN fitting to my valve cover.
Old Apr 14, 2009 | 11:57 PM
Thanks. Any more info on your build? Stock bottom end? Amount of Boost? Turbo Size?
Old Apr 15, 2009 | 12:43 AM
MikeGyver's Avatar
I've got more info, pics, and videos in my introduction thread here https://www.camaroz28.com/forums/sho...d.php?t=664161
HOFFICER
Apr 6, 2020 10:36 AM
RUENUF
Mar 13, 2016 03:39 PM
R@mpage
Apr 20, 2015 10:02 AM
QuickSilver02
Apr 7, 2015 11:12 AM
