What diameter driveshaft
Old Mar 3, 2009 | 09:19 PM
z28ke's Avatar
What diameter driveshaft are you guys running with 12-bolts and 9" rearends. I'm about to buy a strange 12-bolt and want to upgrade my DS along with a number of other things. Since i installed the S-trim every time i drive it the rearend gets louder. thanks
kevin
Old Mar 4, 2009 | 12:01 AM
3" chrome moly
Old Mar 4, 2009 | 06:35 AM
AL SS590 M6's Avatar
Moderator
Originally Posted by Injuneer
3" chrome moly
ditto
Old Mar 4, 2009 | 10:20 AM
Z-RATED94's Avatar
Originally Posted by AL SS590 M6
ditto
Double ditto!
Old Mar 7, 2009 | 11:18 AM
z28ke's Avatar
i guess a 3.5" is overkill then. Whats the advantage of chrome moly over DOM steel. The guy said the DOM steel 3" is rated at 1200hp, but is it heaver or what? Its also $300 and i'm guessing chrome moly run more? thanks
kevin
Old Mar 7, 2009 | 07:00 PM
rexcellent's Avatar
chrome moly is stronger than normal DOM steel so you can use a thinner wall thickness and still have the same strength, ie: lighter piece. I don't know if they use a thinner wall thickness or not but it will be stronger for sure.
Old Mar 7, 2009 | 08:20 PM
A buddy of mine ran the Mark Williams 3" chrome moly DS in his 1,350HP 30th SS (not an LT1 block), running low 8's.
ryanhilsgen
9
Sep 21, 2015 07:34 PM
Slayer
Aug 17, 2015 03:55 PM
Aug 17, 2015 09:50 AM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
realistyc
Jul 28, 2015 07:32 PM
