17x9.5" 46mm offset help
Old Jan 9, 2009 | 12:23 PM
78Z28350's Avatar
Where will the outside edge of my wheel/tire be on a 17x9.5" wheel with a 46mm offset? I know 46mm pushed the wheel outward more but how much? Do you think there would be a problem with it rubbing the fender? Thanks.
Old Jan 9, 2009 | 12:43 PM
bluz28's Avatar
Should be no problem at all!
Old Jan 9, 2009 | 03:10 PM
This set of OZ Racing 17x9.5's has a 49mm offset. Your wheel will stick out 1/8" more than these. I don't think you would even notice it. At full lock, on a seriously lowered car, the tire might rub on the plastic fender liner.
Old Jan 14, 2009 | 05:45 PM
94SLUG's Avatar
This is 46mm on 18x10.5 all 4... Rears took some mods not much..
Old Jan 16, 2009 | 08:31 PM
1996impalass's Avatar
Those 18's make your car look awesome
Old Jan 17, 2009 | 10:10 AM
Just keep in mind that a 46mm offset on a 10.5" wide wheel will not position the inside or outside edges of the tire at the same place as a 9.5" wide wheel with a 46mm offset. The outside edge of the tires with his 9.5's will sit about 1/2" deeper than with your 10.5" wheels, and he will have 1/2" less backspace, eliminating the issues of the inside edges of the tire hitting anything. He should not require any modifiactions at all.
Old Jan 21, 2009 | 11:47 AM
94SLUG's Avatar
Thanks 1996imp....
Fred you know best......
G-BODYT56
Jan 14, 2022 11:14 PM
Henson071
Dec 30, 2015 09:55 PM
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
JordonMusser
Feb 13, 2003 07:26 PM
blksunshine
Oct 14, 2002 01:01 PM
