roller pilot bearing
Old Jan 3, 2009 | 04:11 PM
Wicked 97TA's Avatar
When I put my transmisson back in my car should I use the regular pilot bearing that came with my clutch or should I get a roller one? Is there any advantage to having a roller pilot bearing?
Old Jan 3, 2009 | 04:20 PM
RUDEDOG's Avatar
Use the solid bushing. The rollers tend to fail sooner from what I have seen.
Old Jan 3, 2009 | 04:38 PM
Green96Z's Avatar
+1. The bearings can seize up and explode. Go with a bushing.
Old Jan 4, 2009 | 09:45 AM
rcguy_77's Avatar
I had my transmission started making noise . it sounded like it was the throw out bearing but
once i got it apart the noise was coming from the pilot bearing .I did not put a
needle bearing back I went with a bushing instead
Old Jan 4, 2009 | 10:15 PM
Kevin Blown 95 TA's Avatar
The roller bearings are fine, but some people put them in with just the grease they come with, which is insufficient. They need extra grease, then they will last like they are supposed to.
Old Jan 5, 2009 | 09:35 PM
rskrause's Avatar
Moderator
I avoid pieces with those little rollers when I can. I have lost a couple of engines to failed roller bearings (once in a cam button, once a lifter). Since the advantage is negligible, why risk it?
Rich
Old Jan 5, 2009 | 10:46 PM
I took the tranny out the other day and took it to the guy that is gonna rebuild it. I was under the car today looking over things and it looks like to me it has a roller pilot bearing in it. As far as I know the tranny has never been out of my car. Did any F-Bodies come with roller pilot bearings?
Old Jan 8, 2009 | 07:04 PM
go2fast's Avatar
If you use a solid bushing make sure it's not a cheap one with high iron content. A magnet should NOT stick to it. It will wear your input shaft if it does.
Old Jan 13, 2009 | 09:42 AM
PoorMan's Avatar
Zoom makes a high dollar bushing made out of some type of synthetic poly material. About $50 in the Summit catalog.
G-BODYT56
Jan 14, 2022 11:14 PM
13qtr
Oct 28, 2016 08:11 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
