Going twins, couple quick questions.
Old Dec 18, 2008 | 09:22 PM
reamo04's Avatar
Okay, so, im giving myself a christmas present...just like last year. But this year, instead of a garrett GT88, its going to be two smaller turbos. Goal is 650ish at the wheels, and i found a pair of turbos perfect for it. I know several people using them, and while they are cheaper turbos, they are well proven.
how are you guys doing your oil feed line? -4 line that splits into two -3s?
And on the same note, how about drain lines? two smaller lines that connect into like a -10 line? or just two seperate spots in the oil pan?
thats really the only questions i have, thanks in advanced.
Old Dec 18, 2008 | 09:31 PM
c0rey's Avatar
What kinda turbos?
Old Dec 19, 2008 | 09:51 AM
jsetzer's Avatar
You change your mind too often
I thin I am sticking with my 70 for now.... half way thought about adding a second one of them.
I've seen them split like you are talking about, I have also seen somebody put a t in the top of one turbo and just run them in series.
Old Dec 22, 2008 | 01:02 AM
reamo04's Avatar
see, i have two friends with twin turbo mustangs, and they both run a seperate oiling system for their turbos, i.e. each turbo has a pump, small reserve tank, and returns to that tank so they are completely isolated from everything else which i could do it that way, but it'd be a PITA
Old Dec 22, 2008 | 06:50 AM
97WS6SCharged's Avatar
K.I.S.S. principle works best here.
Run #4 to a T and #3 to each turbo. Mount them high so they can drain back into the pan. No extra pumps to fail, no extra oil supplies to change, faster heat up times and it's very simple to setup.
In keeping with K.I.S.S., your goals are quite achievable with a single turbo. You would cut down on weight and piping complexity over twins though admittedly, you lose some ohhh factor.
Old Dec 22, 2008 | 09:13 AM
jsetzer's Avatar
As far as goals go - I'm sticking with the t70. I've already made almost 600 to the wheels - I know the turbo is more or less maxed out, but I have not done any tuning.
Old Dec 23, 2008 | 11:10 PM
reamo04's Avatar
i couldnt get any more power out of my t70 and it was right around 620 at the wheels
The twins i can get 700ish out of without a doubt
also, ws6supercharged, i dont need piping for twins...they bolt straight onto my headers
nice thing about runninga n alt. only setup, is i can use the SSautochrome headers...
Old Dec 31, 2008 | 08:35 AM
SMOKNZ's Avatar
I thought the SSautochrome headers would not fit due to our shock towers. Have you test fit these headers? I looked into these as well (I have an alt only setup) and was told they wouldn't fit. Are you going to Mod them?
https://www.camaroz28.com/forums/sho...d.php?t=639734
Guess nothing was difinitive, let me know if you get them to fit!
Bill
Old Dec 31, 2008 | 12:55 PM
reamo04's Avatar
Bill
i have not bolted them up yet. I was told from the flange to the furthest part out is 5", should give us JUST enough room for those of us running solid mounts so nothing will move. Otherwise, i have heard of people cutting 1/2" off the primaries
Eitherway, i will make them work
as far as the turbos, they are .63 a/r 50 trims internally wastegated.
Old Dec 31, 2008 | 03:21 PM
RealQuick's Avatar
Bill
I believe thats the problem.
Old Dec 31, 2008 | 03:51 PM
reamo04's Avatar
idk, i have seen them in a 4th gen before, so not sure. I will make them work though
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Fastbird93
Apr 9, 2016 07:01 PM
Ringmaster72
Feb 25, 2015 03:15 PM
