Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
wierd hard start problem
Old Nov 13, 2008 | 01:04 PM
lt1cruzin's Avatar
Ok here goes.Sometimes when i go somewere,go in for a bit then come back out, my 93 lt1 is hard to start.I dont hear the pump relay and if i let it sit and try it again,the relay will click then finaly start. Iv replaced the relay and its still doing it.It compleatly shut off going down the road one time but only once.It was like i turned the whole car off.When it finally starts,i have a low erratic idle.It idles at 600 and around 500 in gear.The car misses but never dies.always starts right up,no miss when cold.Any ideas?Oh new opti plugs wires this summer.
Old Nov 13, 2008 | 05:02 PM
lt1cruzin's Avatar
Update:Had the ICM checked out.Parts store kept resetting the test for about 30 min.It got hot, but checked out good.Was cool enouph to handle. I Have a piece of wire, so next time it does it i can hook up the pump relay bypass to see if its my pump or something else.Update:Went to work, stalled.Tryed the fuel wire by the computer .The pump worked so its not that.
Old Nov 14, 2008 | 04:41 PM
Check your ECM for codes. That may turn up problems with the IC Module, and with the low resolution pulse from the Opti, both of which may cause it to stall, or prevent it from starting. You can scan your 93 simply by shorting the pins in the ALDL connector, to "flash" the codes on the SES light.
http://shbox.com/1/dlc2.jpg
The PASS-key system may also prevent it from starting.
Old Nov 14, 2008 | 04:59 PM
lt1cruzin's Avatar
Scanned codes at Autozone.Nuthing.Im thinking it still might be my pump cause i was using thicker wire than whats on my car to bypass the relay, and it started to melt.Like pump is pulling to many amps.
Old Nov 16, 2008 | 03:19 PM
lt1cruzin's Avatar
Well it gradually starts to miss,lopey idle then stall.i had it idling for two hours and never changed but once I got the rpms up,and drove it a few miles it started to miss like it was going to shut off again but didnt.The coil sounded kinda noisy.I know its supposed to make noise cause its producing high voltage but this was louder than normal.
Old Nov 16, 2008 | 10:30 PM
Did AutoZone use the correct OBD-I scanner?
Old Nov 17, 2008 | 09:20 AM
lt1cruzin's Avatar
Good question.It asked for the vin,year ect .Then it said no codes available.I have a code key,looks like as key with two prongs,and still flashed 12 over and over,no codes.Im now getting a strong fuel smell under the hood.I cant tell if its a raw,or not fully burned smell like running rich.Only happens while running.All i know is its perfect if i let it sit at idle even for a long time, but as soon as i drive it a little,the idle rpms come eratic.then it shuts down and it takes 5 to 10 min to get it running again.
Old Nov 17, 2008 | 10:38 AM
lt1cruzin's Avatar
It did it again but this time i was hearing a loud click were the vats relay is located, then it started.I might take a look at that relay.I dont always hear the relay when it starts.Mabey its going out.
Old Nov 22, 2008 | 11:34 PM
Fatdog2's Avatar
Might check the map sensor.It's that little black thing on top of the intake manifold.If the gasket is toast,this will do that.Also,check to see if the coil wire is good or on tight.hope this helps.(of course you have changed the gas filter).
Old Nov 23, 2008 | 10:52 AM
Pull the vacuum line off the fuel pressure regulator and check for raw fuel.
Verify that the coolant temp sensor in the water pump is accurate.
http://shbox.com/1/4th_gen_tech2.html#ect
Old Nov 23, 2008 | 03:19 PM
lt1cruzin's Avatar
Thanks guys.My opti needs a new cap, rotor anyway,so im replacing it and have a lifetime on opti so doing all that, new temp sensor,checking regulater ect.
Old Nov 23, 2008 | 06:41 PM
lt1cruzin's Avatar
well finaly had a buddy w me when it shut off.no fire from coil so tracking it down.
Alex Barnes
Jan 24, 2015 10:21 PM
HCz28
Jan 11, 2015 11:21 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
formula79
Jul 13, 2002 09:06 PM
