PCM help
Old Nov 2, 2008 | 04:30 PM
Black 97 SS's Avatar
PCM help
Hello I have a scanner I bought from murray's for odb II. The scanner worked good for a couple months than when I would try to connect it to the pcm it would just power off. Thought it was the scanner so I had it replaced, still does the same thing. Do you think my pcm is messed up or the programming port? Thanks Jason
1997 Camaro SS #1039 M6
LE1 2.00-1.56 valves, Matched Intake, Holly 58mm, CC306, 30lb injectors, Pacesetter Long tubes, TTL exhaust, No Emissions, Mad Z28 Tune, 4:10’s, Level II Suspension, Sphon LCA'S, Spohn Panhard, Hotchkis swaybars, BFG KDW’s.
Old Nov 2, 2008 | 06:50 PM
2001NBMZ28's Avatar
Dunno, but first thing I'd check it to be sure you have power to the DLC port, maybe a fuse is blown?
Old Nov 2, 2008 | 09:11 PM
Yep, check the cigarette lighter fuse. It feeds the DLC. Some scanners need this power.
Old Nov 4, 2008 | 05:49 PM
Thanks guys. That was it, must of popped it with my Ipod. I was getting scared thinking it was something serious because I just had the whole car apart last winter
LE1 2.00-1.56 valves, Matched Intake, Holly 58mm, CC306, 30lb injectors, Pacesetter Long tubes, TTL exhaust, No Emissions, Mad Z28 Tune, 4:10’s, Level II Suspension, Sphon LCA'S, Spohn Panhard, Hotchkis bars, BFG KDW’s.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
