Fuel pressure while spraying....
Old Jan 2, 2003 | 06:06 PM
ElkyRacer's Avatar
Just how much should fuel pressure drop, if any at all? I just put a electric fuel pressure gauge on the car to see what its doing while spraying. The only place I could put the sending unit, was the feed line for the fuel solinoid coming off of the test port. Its right next to the solinoid. I really wanted it closer to the fuel rail so I could rule out sudden pressure drop due to the sending unit being so close to the solinoid. When I sprayed it (150), it droped from around 42psi to about 35psi. Im thinkin thats quite a big drop but Im not sure. If so, looks like its time for a new intank pump.
Thanks.
Kyle
Old Jan 2, 2003 | 11:20 PM
Z28ROC's Avatar
I would say it's definately time to upgrade your pump.
I was seeing similar amounts of pressure drop, on the stock pump. Now I get 0 pressure drop on a 175 shot. My sending unit is mounted in the same place as yours.
Old Jan 3, 2003 | 12:50 AM
ElkyRacer's Avatar
Dang, I knew that was coming. Not really what I wanted to hear. Guess Ill be lookin at upgrading to the Racetronix kit as soon as I can.
Kyle
Old Jan 5, 2003 | 10:40 PM
funina91ss's Avatar
I have a walbro intank 255 lph brand new 110 shipped!
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Jul 4, 2005 05:00 PM
