window motor
Old Oct 25, 2008 | 05:34 PM
snareman's Avatar
window motor
0k--gonna be replacing my drivers side motor in my 93 z. any suggestions or tips, I have the writeup by shoebox. is there anything I can use besides a c clamp to hold up window?thanks
Old Oct 25, 2008 | 06:33 PM
moparman's Avatar
Shoebox mentioned someone using a table leg. Although I didn't use a table leg, I did use the leg off an old chair. I measured the distance from the bottom of the window to the door bottom and cut to the proper length.
I used a Dorman, and I noticed it's somewhat different from the GM motor. It fits correctly, but it sounds different, and seems to be a bit faster.
Old Oct 25, 2008 | 08:10 PM
Green96Z's Avatar
I've used a small block of wood and nothing before. Unless the regulator is loose, the window is not just going to fall all the way down when the motor comes off, there is still some resistance on it. Having something there is just added insurance. I would recommend using some screws and nuts for the motor, and make sure you have lock washers and use loctite (mine backed off once).
Keenan
Jan 19, 2023 12:24 PM
warmeck
Feb 2, 2015 12:44 AM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
