Loctite bolts
Old Oct 5, 2008 | 01:33 PM
PWR-TRIP's Avatar
Loctite bolts
After i installed my longs, my header bolts are becoming loose. I have to tighten them quite abit. I just did today and the noise went away. It sounds like a really bad lifter tick and it's very annoying. Would it be safe to loctite them? What wrench would i need to tighten them?
Old Oct 5, 2008 | 03:35 PM
mdacton's Avatar
do not use locktite. just keep tightening them...after a while they will be good, a few days maybe.
Its the expansion of the flange and gasket etc.
Old Oct 6, 2008 | 01:54 AM
Green96Z's Avatar
Don't use loctite. Use only anti-seize. You have to keep tightening the header bolts after a couple hot and cold cycles for them to finally seat.
Old Oct 7, 2008 | 08:12 AM
PWR-TRIP's Avatar
Should i tighten them really, really tight or will it snap?
Old Oct 7, 2008 | 04:56 PM
Green96Z's Avatar
What kind of bolts are you using? I think the torque spec is 30 ft. lb. But its impossible to get a torque wrench on every bolt. What I did was torque the front bolt that I could get to, then I used my box end to get a feel for it, then tightened all the bolts in the ballpark. I ended up getting one of these for more leverage:
http://www.sears.com/shc/s/p_10153_1...sName=Wrenches
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
