trouble code
Old Dec 30, 2002 | 07:14 PM
dmoss69's Avatar
trouble code
I have a trouble code of 36.
Faulty high resolution pulse or multiple low resolution pulses detected in ignition system.
WTF?
I have everything new. New opti, new wires, new plugs. Why am I getting this code. The only thing not new on my car is the coil.
Thanks.
David Moss
Old Dec 31, 2002 | 12:47 PM
You are losing the high res pulse, at least intermittently. Have you checked the wiring harness? A faulty connector or corrosion on the terminals will screw the signals up. Remember, there is one connector on the Opti, and another on a bracket on the passenger side of the intake manifold - the grey 4-pin connector near the EEC solenoid. Also, check for a high voltage wire running close to and parallel to the Opti harness, causing HV inductive interference.
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
