Reverse lockout..broken?
Old Sep 3, 2008 | 05:34 PM
Jazsun's Avatar
Just tried to pull my car out of the garage and it started happening. When I go to find reverse It just feels like a wall and if I push up and to the right I get into 5th. The only way to get into reverse is to use both hands and push hard in the top right corner and then it goes in. Once in it acts fine and all and can be pulled out easily. It acts the same w/ the car off or on. Is it unusual for a reverse lockout to go bad? If it was a transmission or synchro problem wouldn't it grind?
Old Sep 4, 2008 | 05:58 PM
Green96Z's Avatar
Sounds like the solenoid, and yes they do go bad. Pull it out of the tailhousing and see if you can shift into reverse. If it shifts easy, then that's your problem. To test the solenoid, just hook 12v to it and see if it moves.
The solenoid only disengages with the engine running BTW.
Old Sep 4, 2008 | 11:23 PM
If there's a problem with the electrical part of the solenoid, or with the control circuit, it should be setting P1667.
Old Sep 5, 2008 | 11:03 AM
Jazsun's Avatar
So there should be a code for a broke solenoid then? Would it throw a code even if it were unplugged?
Also when I unbolt the solenoid will I lose tranny fluid?
Old Sep 5, 2008 | 03:19 PM
Green96Z's Avatar
No. Just one bolt holds it in, and there isn't even a gasket on it. There should be very little or no fluid in the shifter housing.
RUENUF
Mar 13, 2016 03:37 PM
blac94Z
Nov 4, 2015 01:59 PM
dolfan324
Jul 17, 2015 10:34 PM
Beave2780
Jul 7, 2015 06:36 AM
jimlab
Oct 6, 2002 08:37 AM
