Clutch is acting up... what's the cause?
Old Sep 3, 2008 | 10:11 AM
GrdLockV6's Avatar
Just a couple days ago I started to notice this.
Occasionally, the clutch pedal will stick down when I let off of it. The clutch will be engaged, but I hafta kinda pop the pedal back up with my foot. Doesn't do it all the time.
I've also noticed there's a lot more play in the pedal. I used to only be able to push it down an inch or so before I started to feel resistance. Now I can push the pedal down almost half way before I start to feel the pressure on it.
Other than that it's still working fine, but I'd like to know what's causing this so I can get it fixed before I go to shift gears and the clutch doesn't work at all. I got the tranny rebuilt about 10k miles ago, and had a Spec Stage 2 clutch installed.
Old Sep 4, 2008 | 06:39 PM
GrdLockV6's Avatar
No one??
Old Sep 4, 2008 | 06:49 PM
stvski80085's Avatar
re
Well are you sure nothing is binding.
Old Sep 4, 2008 | 07:22 PM
JakeRobb's Avatar
Super Moderator
Step 1, make sure your clutch fluid reservoir is full. It's behind the driver side shock tower, up against the firewall, and IIRC you fill it with brake fluid.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
