Shimming rear calipers.....
Old Aug 28, 2008 | 01:30 PM
NJLT1SS's Avatar
Has anybody here had to shim their rear calipers to "center" them over the rotor? I used to have an annoying rear brake squeak. I pilled the rear wheels off and noticed that there was space between the inner pad and rotor, and the outer was always touching. I got 4 washers that are about a 1/32-inch thick and placed them between the caliper and backing plate. The caliper is now centered, with space between both pads and the rotor, and the brake squeak is now gone. Anyone else ever had to do this?
Nick
Old Aug 28, 2008 | 03:26 PM
Probably so. GM makes a shim specifically for this.
Old Feb 24, 2009 | 12:14 PM
cblinkdude182's Avatar
Sorry to bring up an old thread but is this what he was talking about?
If so I need one of those shims...
Old Feb 24, 2009 | 06:06 PM
transAMdriv3r's Avatar
no, hes talking about the caliper holder. your caliper is tilted like that because of the ebrake. I think there is a way to adjust it. It might be on www.shbox.com under the how to section
Old Feb 24, 2009 | 07:51 PM
Ya that's what I thought but I couldn't find anything...
Old Feb 24, 2009 | 08:39 PM
MikeGyver's Avatar
Mine squeels like a pig during body roll on hard cornering. EEEEEEeeeeeeeeeeeeeeeeeeeeeeeeeeeee!!!!!!!!!!!!
Old Feb 24, 2009 | 10:15 PM
Well I'm going to get my brakes looked at this week, I'm tired of this crap...
Old Feb 28, 2009 | 01:37 AM
I took it to the shop and they pulled the shims off of the caliper and it seems so far to be not sticking. Damn that's frustrating, such a small part can cause such frustration...
Old Mar 9, 2009 | 11:49 PM
budgetlt1's Avatar
i've seen that one time before. it was after an axle replacement. the replacement axle had a larger c clip gap and allowed for a little more movement so on a hard turn, the caliper bracket actually rubbed on the rotor. the fix was either to shim the caliper bracket or get a thicker c clip. my 2 cents
96SilverRam
Nov 20, 2016 11:19 AM
HarleyZ28
Oct 5, 2015 06:23 AM
achipfef
May 5, 2015 10:20 AM
BLK1997Z28
May 1, 2015 12:23 PM
