Removing my cats?
Old Aug 27, 2008 | 08:04 PM
lt1stroker's Avatar
Removing my cats?
I want to know the process of removing my cats. Do i need to put a cat. converter in place of it or what? I dont really know the process. any help please
Old Aug 27, 2008 | 09:59 PM
95Blackhawk's Avatar
It has been proven that cats don't take much power from the car. So is there another reason for removing it?
Old Aug 28, 2008 | 12:15 AM
lt1stroker's Avatar
make my car a little louder and sound raspy. its too quiet
Old Aug 28, 2008 | 02:17 AM
Green96Z's Avatar
Cut the cat out and have a straight pipe welded in its place. Or buy an aftermarket off-road y-pipe.
EDIT: Make that CATS. You have 2 on your 96.
Old Aug 28, 2008 | 09:40 AM
slomarao's Avatar
just have someone weld in stright pipes. It wont be that loud. I run around with a open cutout half the time.
Old Sep 5, 2008 | 08:22 AM
2000GTP's Avatar
I'm confused, what would be the point of removing the cats just to install catalytic converters again, if that is what you are asking? Generally, as mentioned, people remove the cat and just have a piece of pipe welded in its place. Others, will gut or hollow out the cat(s). Another option is people will go the route of having a high-flow cat installed probably so they can still satisfy emissions regulations. Seeing that you have a dual-cat setup, the cat on the drivers side is a relative pain to get to. I don't know how easy that will be to rig up a piece of pipe for and I don't know if there are many aftermarket cats that will fit those odd dimesions. But once again, as mentioned above, the cats are not robbing you of very much power anyway so it might not even be worth the effort in removing or replacing them.
Old Sep 6, 2008 | 07:26 PM
mzgp5x's Avatar
I replaced both Random Cats due to blow-out from a FI application. Te car rn great with them, but, the Rt side was blown out. So, I welded (2) 2 1/2" straight pipes in place. Changed every thing with the exhaust. Did alot of additional work to quiet it down and flow with a FI application. The Random Cats are a really a good flowing cat in my opinion.
R@mpage
Apr 20, 2015 10:02 AM
lt1matt
Mar 21, 2015 07:35 PM
alex5366
Mar 8, 2015 11:32 AM
Iamherefornow
Jan 26, 2015 04:57 PM
alphaauto
Jan 23, 2015 07:42 AM
