T56 ppl please look. Good deal or not?
Old Jul 29, 2008 | 09:40 AM
powerslide350's Avatar
Ok a guy I work with has a t56 out of a 95 fbody. Its the tremec t56 not the borgwarner. Anyway it is missing the rear section of the transmission, the tailshaft housing I guess. and its missing the bell housing.
He has the tail section but it is broken from being droped. He has all the gears and parts with him in a box that came out of the tail section.
He was asking 400 bucks for it and I offered 200. I think he is going to take it.
Is this a good deal? Or should I run.
So basically ill be getting a t56 that needs to be torn down, a tail section found and a bell housing found. All for $200. Basically its a core.
Thanks for any suggestions, Josh.
Old Jul 29, 2008 | 09:50 AM
JakeRobb's Avatar
Super Moderator
The Tremec and Borgwarner units are identical. No reason to make a distinction between them.
For $200? Sure. I had to replace third gear in my T56 this past winter, and the gear alone was $130.
Call the people at SixSpeedsInc.com and ask them what it would cost to fix it. They did a full teardown and rebuild of mine for $1200, including replacing 3rd gear and a bunch of other upgraded parts. The freight to ship it to them (they're in the Houston area) was $200 round trip.
Old Jul 29, 2008 | 05:39 PM
Hard to understand how it could be a Tremec..... Borg-Warner didn't sell the T56 manufacturing to Dana/TREMEC until 1997. I have an original trans out of a 1997 SS, and it was still a Borg-Warner.
Old Jul 29, 2008 | 05:47 PM
Green96Z's Avatar
If it IS a Tremec and not a Borg Warner, you need to verify that the front faceplate and input shaft are for the LT1, not the LS1. When I received my T56 from SixSpeedsInc, whether by accident or not, the case is from a Tremec T56, but it is built for my 96 Z. So all you have to verify is compatibility.
SmokinZ28lt1
Feb 5, 2015 04:33 AM
ModdedNerd
Jan 1, 2015 10:56 AM
Brandon Wittmer
Dec 8, 2014 07:53 PM
Matt96Z
Aug 24, 2002 11:44 PM
lbrowne
Aug 22, 2002 06:21 PM
