Autocross and Road Racing Technique There is more to life than a straight line
do lca relocation brackets do anything...
Old Dec 26, 2002 | 04:16 AM
stik6shift98's Avatar
i have bmr lca and i was wondering if i should get relocation brackets.....and how hard is it to do...
Old Dec 26, 2002 | 06:57 AM
Norm Peterson's Avatar
Re: do lca relocation brackets do anything...
The answer depends on how you're going to use the car.
If it's going to be mostly dragstrip and other straight line zero to ?? running, then by all means, and you'll probably want to use the lower holes if you have a choice. At the cost of it feeling "loose" in hard cornering and more likely that you'll get brake hop though.
If handling is the priority, then the answer is "maybe". IOW, only if you need to lower the axle end to get the LCA's horizontal. Most likely this will be only if you've lowered the rear with shorter springs or if it's dropped a bit under the weight of your sound system.
In any event, weld them on, either by getting the weld-on's or by welding up the bolt-ons after making sure that they are aligned correctly. If you're not familiar or comfortable with this kind of work, better farm it out. Your rear axle alignment depends on it. Preferably bring it to a shop that has some experience in race car fabrication (as opposed to a muffler shop simply because it has a lift and a welder). Ought to be enough places that have circle track or back-halved strip car experience out your way to choose from.
Norm
Old Dec 27, 2002 | 01:16 AM
Dr.Mudge's Avatar
If the car is lowered, use them, after lowering an no LCA my car was very tail happy, not a good thing at all.
Old Dec 28, 2002 | 06:21 AM
i guess il do it.......how hard is install????
could i do it myself????
Old Dec 28, 2002 | 06:16 PM
Dr.Mudge's Avatar
If you buy the bolt ons, yes you could easily do it yourself. If you use locktite I'm not sure you'd want to use red, ask him for an opinion perhaps, you can always have it welded on later down the road.
He has install pix on his site, and yes its pretty easy.
Old Dec 29, 2002 | 05:48 AM
I'm not sure you'd want to use red???????
what r u trying to say
should i get bolt ons.......
Old Dec 29, 2002 | 09:26 PM
Dr.Mudge's Avatar
You can do weld ons, somehow I thought you were doing this yourself, most people dont have welding equipment, and if they do they usually are used to welding and I figured wouldn't be asking about this stuff
Old Dec 30, 2002 | 06:09 PM
And the reason for not using Locktite red is that if you ever wanted to remove them you'd need to use torch heat to break the anaerobic bond in order to loosen the nuts. If you didn't ever want to remove them, you might as well have welded them in the first place (once they were correctly located).
Norm
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
War Engine
Sep 18, 2015 07:28 PM
realistyc
Jul 28, 2015 07:32 PM
Boss002
Jul 24, 2015 10:47 AM
