lca relocation brackets on a lowered car
It's very unlikely. They sit directly to the inside of your rear tires, so as you drive over something, even with one wheel, the LCA bracket is lifted with the wheel. So while technically they are a low point, it's not in a place that you'd typically have an issue with.
Dave
Dave
You'd probably want to get his if you have his LCA, some people with other LCAs had complained that his relocation brackets were too wide and used spacers (washers) to get them to fit right.
Check his site for info or email him, if your car is lowered and doesn't have the brackets you should see a very obvious geometry issue in the back, and the rear gets very squirly that way.
To check the LCA, you want to see where the height of the front of it is, relative to the rear. So measure from the ground up to the bottom of the front, then the rear of the LCA. If you're a road racer type, then those should be equal distances (I'll just make up, "within 1/2 of each other"). If you're a drag racer, you want the rear of the LCA lower than the front, by an inch, maybe two. Right now with your springs, the front it probably lower - not good for either scenario.
On the brackets. Did your BMR LCA's fit in the stock mounting points on your axle, without bending the bracket they sit in? If so, I'd get GW or Spohn LCA drop brackets. If the BMR LCA is wider than stock, then you want to get the BMR bracket. Either way, you want to get them welded on.
Dave
Dave
