ECU engine codes
Old Jun 22, 2008 | 11:11 PM
Mentu13's Avatar
ECU engine codes
I recently changed the ECU on my car. The new ECU has been reprogrammed to my engine tune. The problem I have now is that the transmission will not shift into overdrive most of the time. The way I can get it to work sometimes is to restart the car. What I have found is that the ECU is showing engine codes C0237 and C0240. I can't figure out why i get these codes and how to get rid of them.
Old Jun 22, 2008 | 11:34 PM
The GM code lists for the 99 LS1 do not list either of those codes under engine or transmission.
http://service.gm.com/gmspo/mode6/
Old Jun 22, 2008 | 11:44 PM
Mentu13's Avatar
C0237 - Rear Wheel Speed Signal Erratic
C0240 PCM Traction Control Not Allowed
The main thing, is the trans not going into overdrive. I don't know if it is from these codes or something else. Through HP tuners, the tuner can manually lock up the converter, but only sometimes, otherwise the ECU won't even send the signal to lock up. He cleared the codes and the trans worked fine for about 5 minutes, then as soon as the codes came back, the trans wouldn't lock up.
Old Jun 23, 2008 | 05:33 AM
Those are neither engine or tranny codes. They are for the EBTCM. Have you checked the rear wheel ABS/TCS sensors?
Old Jun 23, 2008 | 09:39 AM
Mentu13's Avatar
I haven't looked at those yet.
Would those going bad cause the EBTCM to not let the trans shift to overdrive?
Old Jun 26, 2008 | 08:02 PM
Mentu13's Avatar
Here's what the problem is, I took a GPS and compared it to the car, what I found is that the speedometer is 2% off, the trip meter is 2% off and the difference between 26" tires and 25.5" tires is 2%. The computer thinks there are 26" tires but they are really 25.5"
What is happening is the trans is reporting one speed, but the ABS/TCS is reading a different speed, so the conflict is turning off the overdrive. If i turn off the TCS, the car goes into overdrive with no problems.
Old Jun 26, 2008 | 10:21 PM
The rear wheel ABS/TCS sensors will be "off" by the same % as the tranny output shaft (VSS), if its the tire diameter that is programmed incorrectly. Why not try having the correct tire diameter programmed into the PCM, and see if that helps.
Old Jun 27, 2008 | 12:11 AM
Mentu13's Avatar
Well, on Sunday I had "worked" with my tuner, and the tire diameter at the time skip our minds. I will have him adjust that later on this month when I swap out my cam and retune the car.
oldschool
Feb 9, 2016 09:21 PM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
jrp4uc
Jun 19, 2002 06:20 PM
