Windshield wiper problem
Old Jun 17, 2008 | 12:44 PM
lovemyblackz28's Avatar
lately my wipers are bing weird. I will turn them on when it rains, when Im done using them I will close them. Problems is when i close them, they dont go all the way down. They stay in the delay mode, not entirely down. The only way i was able to get them to go down was by turning the car off. Once I turned the car back on, the wipers go down to its original off position. The wiper motor dying?
Old Jun 17, 2008 | 03:14 PM
Oxygen454's Avatar
If it is like the camaro wiper problem I had, your not going to like the answer.
The story...
I took our 97 to the mechanics and they tried adjusting and switching the arms under the hood. With no avail, they decided it was a one of two moduals that make the wipers work. The first one was $500 from chevy, the second, $1000!!! So we went for the $500 dollar modual and that still didnt work. The wipers did the exact same thing as you described. So we were about to put the thousand dollar part in (which we got for way less at a autowrecker) and just before, the car got hit by a pickup truck and got totaled.
All thanks to a semi truck and a pickup, my camaro was no more.
So hopefully that will help you. I don't want someone to go through the expensive experience of replacing unneeded parts like I did.
Old Jun 17, 2008 | 03:45 PM
The story...
Wow, sorry to hear about your loss! Did this wiper problem always happen with you? This problem of mine is not consistent. Only happens here and there.
Old Jun 17, 2008 | 04:07 PM
Oxygen454's Avatar
The problem started off as only once and a while but then went constantly. It got to the point that it was stopping half way down the window. I had to open the window while driving down the road and pull them down after I turned them off.
Looking at the schematics in Haynes, there is a schematic for the window motor which has a "end of sweep switch" with in the motor mechanism. And as I think about it more, I think the one modual was part of the motor and the other was part of the switch control system. So this being said, I think the problem lies in the modual that is part of the window motor.
Old Jun 17, 2008 | 04:26 PM
Oxygen454's Avatar
Here is the schematic showing the switch in the window motor modual
Link of schematic to my fquick page Click Here
Old May 17, 2010 | 08:43 PM
graybeam's Avatar
Wiper Issues
I have a 94' Z28 with the same problem. For years it would randomly set the wipers off if I took a sharp corner. Then the wipers would get caught about 4 inches higher when they were turned off. Sometimes it would fix itself, finally it stopped fixing itself and stayed about 5 inches off. Now, as of today, I used the windshield cleaner and now the wipers won't turn off at all. I have to twist the manual on/off at just the right interval to get it to stop at about 6 inches above where it should be. Very annoying... So a wiper motor should fix the issue? Camaros are scarce in u-pull-its around here.
Old May 18, 2010 | 02:03 PM
Skywise's Avatar
It's the wiper motor. The cold solder on the circuit boards in the motors go bad.
Same thing on my '97 - wouldn't go down, then wouldn't delay, then wouldn't shut off (I just pulled the fuse for a few months).
Old May 19, 2010 | 08:30 PM
byrons1502's Avatar
This is from a repair website i pay for. I don't have a car in front of me to check
1. Check the crank arm assembly for being broken. This is the piece that bolts to the wiper motor shaft with the spring wrapped around it.
2. Check the metal tang sticking up from the motor mounting bracket to see if it is broken off or bent. This tang has to come in contact with the arm sticking out for the crank arm assembly in order to park and shut off the wipers
The solder boards(if it has one) can be soldered and rechecked. Look for cracks in the solder joints.
Old Oct 25, 2015 | 12:51 AM
94z28blueprint's Avatar
Re: Windshield wiper problem
Yo! I'm pretty sure that my issues has to do with the "little metal tang" but I'm really not sure what it is!!!! I'm like 99% sure my motor is electrically operating properly. Here's a video I posted about it: https://m.youtube.com/watch?v=hneo9uBWZ_M&feature=youtu.be
Information is appreciated.
Old Oct 25, 2015 | 08:47 AM
There is a wiper linkage and motor diagram showing the "bracket, wiper motor" in the 94 factory manual - Volume 1 of 2, Part 2 of 2, page 8E-15. Isn't clear what part of that bracket would be call a "tang".
You can download the 94 factory manual for free, here:
LINK: 4TH GEN SERVICE MANUALS - Firebird Nation
Maybe looking at the linkage diagram would help you figure it out.
Red Hawk 94
Mar 18, 2019 04:03 PM
R@mpage
Apr 20, 2015 10:02 AM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
stopthatman
Feb 9, 2015 09:00 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
