Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
loosing fuel pressure
Old Jun 14, 2008 | 09:56 AM
blair's Avatar
i just recently replaced the fuel pump with the granatelli 255lph and i got a new fuel pressure regulator and new fuel filter and i had the car running at 45psi and when i turn it on it will run and then when the engine warms up it drops to 10psi and the motor shuts off what could that be cause it only shuts off when the engine gets hot
Old Jun 14, 2008 | 11:29 AM
If the fuel pressure suddenly drops 10psi on warm up, its most likely the fuel pump. Have you checked to make sure you have good voltage to the pump?
What brand fuel pressure regulator did you buy?
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
