Just finished LT's and true duals.
Old May 27, 2008 | 02:25 AM
greenday3437's Avatar
Well, just finished putting on my hooker lt's and true dual exhaust with an x pipe and bullet mufflers..
Once small bit of advice i have.. When doing LT's, try to get a friend or someone to help out. I wish i would have had someone to help me out, would've made things a lot easier..
Also, that damn temp sensor on the drivers side, i broke it.. I was being very careful of it, got the long tubes completely installed and the steering shaft back on without breaking it.. I broke it with my hand when routing the spark plug wires.. So gay
I will post pics/ vids tomorrow
Old May 27, 2008 | 09:02 AM
95_LT1Z's Avatar
cool cool! you will definitely enjoy it. i was surprised the difference longtubes actuall make. dont feel bad about breaking something. i think that is just the way it has to go with putting longtubes on the lt1 lol! i broke the crank position sensor on mine and had to replace it. so at least they are minor things. do you have the exhaust dumped at the axle? cant wait to hear her roar!
Old May 27, 2008 | 09:08 AM
2000GTP's Avatar
Good job, I agree, an extra set of hands does help, especially when trying to get the headers lined up and steady so you can get the bolts started. I broke the coolant temp sensor as well, luckily it was a 20 dollar part from GM so it wasn't the end of the world.
Old May 28, 2008 | 02:09 AM
Yeah it's dumped at the axle, i drove it just now for the first time and it seemed like it was idling somewhat high, so when i got home i looked around and realized i forgot to hook up that little vacuum line elbow thing that's after the MAF sensor, hopefully thats what it was
Old May 28, 2008 | 02:11 AM
Yes thats pretty much what i needed help with.. I had to sit on top of the engine and hold the headers just right with one hand and start the bolts with the other..
On another note.. I've read that most people put the headers in from the bottom, and some put the drivers in from the top.
I put my drivers in from the bottom, and for the passenger, i removed the valve cover, put the header in as far as i could get it, then jacked the engine up, it literally fell right into place by itself, it was easy (this was after tryin to wrestle it in from the bottom for a while)
9t4lt4z28
Oct 2, 2015 10:28 AM
CARiD
Sep 30, 2015 05:44 AM
Boss002
Jul 24, 2015 10:47 AM
