PCV.. .what do you F.I. guys do to keep that from popping out?
Old May 20, 2008 | 07:24 PM
DirtyDaveW's Avatar
Just looking at that as I install the motor. I remember before, you could slip it out with just a little finger tension before. What do you guys do to keep it plugged in under boost?
Thanks!
Old May 20, 2008 | 08:29 PM
Kevin Blown 95 TA's Avatar
Dave - you have that much crank case pressure? That's not good. Maybe I'm misunderstanding you but that fitting on the front of the manifold holds the hose real well and the one in the side where the PCV is located is just a crankcase passage. Now if your hose is popping off the pcv valve itself, then clamp it on there with something. I have about 15# boost and never had any prob with the pcv coming off.
Old May 20, 2008 | 10:20 PM
DirtyDaveW's Avatar
Okay. Thanks Kevin
Old May 21, 2008 | 12:39 PM
jammer94's Avatar
how about not using pvc and using an actual alum intake pipe which has a bead on it so that the hose cant slip off of it, do it right the 1st time besides pvc holds in heat like a Mo'FER
cobrakilling101
14
Mar 17, 2015 10:42 AM
hotrod 5210
Dec 22, 2014 07:28 AM
JSK333
Sep 9, 2002 10:33 PM
Red97LT1
Aug 7, 2002 05:45 PM
ced8
Jul 8, 2002 11:03 AM
