315/35-ZR17 Tire pressure?
Old Dec 19, 2002 | 06:04 PM
JDohn2001's Avatar
I just got new 17"x11" ZR1 wheels and 315/35-ZR17 BF Goodrich T/A KD tires for the rear of my car. What should my tire pressure be for normal driving. Right now I have them at 35psi.
Jason
Old Dec 21, 2002 | 12:46 AM
JDohn2001's Avatar
Anybody?
Old Dec 21, 2002 | 11:45 AM
Xride's Avatar
should say right on the side wall, but i think 32-35 psi is about average for a tire.
Old Dec 21, 2002 | 02:01 PM
You can't go by what is marked on the tire sidewall.... that's the pressure required to achieve the marked load rating, at max rated speed. On a 4th Gen, the 315/35-17 isn't loaded anywhere near max rating (1,874#), and the center of the tread would bulge considerably at the 44psi that is (probably) marked on the sidewall... I know that's what's on my 275/40-17 KDW's and also on my 315/35-17 Drag Radials.
I run 30-32psi in the DR's with not problems..... good traction, reasonable ride. The KD's would probably be happier at 32psi. Give it a try, paying particular attention to the tread wear. A tread depth gauge is an excellent investment when running wide, expensive tires.
Old Nov 28, 2013 | 08:17 AM
Skyrider's Avatar
Re: 315/35-ZR17 Tire pressure?
I also have Nitto P315/35/ZR17 on 10.5" rims on the rear and P245/40/ZR17 on 9.5" rims on the front of a 2002 Z28. I have been looking for guidance on tire pressure that would give even wear. This is a weekend street driven car so I am not looking for race performance. I have seen pressures quoted that range from 22 to 35 psi. Any guidance from the forum would be appreciated.
Old Nov 28, 2013 | 11:05 PM
As noted above, I found 30 - 32psi to be the best for street use. The only reason you might go below that would be track use.
The 245/40-17 is a bit tricky to predict. That's a 24.7" diameter tire and 1" smaller than it should be. The rears tires are correct at 25.7". The SS and WS6 coupes for example, came with 275/40-17 (25.7") tires. Are you sure you don't have 245/45-17 (25.7")? In any case, I'd say 32-34psi would probably be best.
As noted above, get a tread depth gauge, and monitor the tread wear for evenness.
RichJ
Sep 14, 2002 09:37 AM
Frank95z
Sep 10, 2002 08:30 PM
97bowtie
Aug 25, 2002 11:00 PM
Cap'n
Aug 19, 2002 11:33 PM
wytblur
Aug 5, 2002 02:03 PM
