Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel filter thread size
Old Apr 24, 2008 | 03:32 PM
Hot Rod SS's Avatar
Just need a quick reference. Anyone know what the thread size is for the fuel filter on a 97 SS is? I'm ordering an AN to metric adapter but I need to know what the size is.
Old Apr 25, 2008 | 07:42 AM
Only the outlet side of the stock fuel filter is threaded. Is that where you want to attach the -AN line? If you need the thread spec, go to an auto parts store and measure the threads on the correct replacement filter.
The inlet side is a GM plastic spring-clip design - there aren't any threads. If you want to run -AN lines to both sides of the fuel filter, buy a high quality filter, with -AN connections, and a replaceable filter element. SX makes a good filter. I have one mounted in the stock location.
http://www.injuneer.com/images/photo.../DCP04302a.jpg
Old Apr 25, 2008 | 10:52 AM
mdacton's Avatar
That threaded fittings is a saginaw fitting, I think someone makes adapters for them. Like injuneer siad get a good filter if your going that far.
Old Apr 25, 2008 | 02:41 PM
Hot Rod SS's Avatar
It's a 16mm I believe, here's the part I was needing
But since I didn't check the direction of the fuel filter that isn't gonna work for what I wanna do. Looking to install an inline fuel pump and the threaded side is on the wrong side for what I'm doing...
Soooooo... I found this puppy
but now I need a male end adapter to fit the stock female end quick connect and I'm not having luck in the department trying to find it. Any ideas?
Old Apr 26, 2008 | 01:59 PM
You might want to provide a bit more info on what you are trying to accomplish. Its possible to put an inline pump in without using -AN lines. NOS has a good diagram in there instructions for the 5176 kit. The instruction manual is available online. Otherwise, its hard to understand what you even mean by "I didn't check the direction of the fuel filter that isn't gonna work for what I wanna do. " The stock filter has the spring clip fitting on the inlet side, and the threaded fitting on the outlet side, if I recall correctly.
Old Apr 26, 2008 | 05:13 PM
Hot Rod SS's Avatar
I didn't check that the fuel flow was coming out of the threaded fitting on the fuel filter. I went off by memory and thought the threaded side was facing the tank. When I went to pop the fuel filter off to check the thread size I saw that it was opposite what I had thought. So I can't do what I initially intended because I presumed that the threaded fitting was on the wrong end.
What I'm doing, exactly, is trying to install an inline fuel pump before the fuel filter. It has not been a painless task with trying to find these fittings. I'm half tempted to get another fuel filter, saw off the male end and weld its onto a stainless AN fitting to fit my fuel pump. Either that or just throw in the towel on an inline and just drop the tank for an in-tank pump. Not a fan of cutting a hole in my floorboard so it is/was my intent to avoid an in-tank due to the hassle of dropping the tank.
Old Apr 26, 2008 | 06:24 PM
mdacton's Avatar
Just do the in-tank....its a fairly easy job
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
